Center Diff - In the gearbox or transfer case
I've been curious about this. For my model Evo 6, there is from what I understand a center diff in the gearbox and then a Viscous Coupling Unit in the transfer case. So I've heard some people say the center diff is in the transfer case, and others the gearbox, and maybe both are right?
But what I don't understand is, there is two hollow shafts output from the center diff of the gearbox which connect to the transfer case. What I assumed was the inner hollow shaft was front wheel power, and the outer hollow shaft was the rear wheel power. But if front and rear power is split at the output of the gearbox, does this not have to mean the center diff is ONLY in the gearbox?
Anyone able to clarify my undoubtedly mixed up thoughts?
This should help a lot. It lays out all the parts in a color coded diagram.
https://www.evolutionm.net/forums/sh...d.php?t=149737
"(Black) This is the Center Limited Slip Assembly. It is in the same location on all Evos, but in 03 and 04 it is a viscous coupling. On 05+ Evos it is an active clutch pack that can vary the torque split between front and rear."
So my question is, we have two hollow shafts coming out of the center diff in the gearbox, presumably one is front wheel power and then one is rear wheel. So my question is, if we have the power out the gearbox split already, why is there more center diff stuff (VCU or active clutch) in the transfer case too?
How does the center diff in the gearbox interact with the stuff in the transfer case?
Basically, the differential in the gearbox is an open differential. The viscous coupling or active clutch (in the TC) is connected to both the front and rear outputs of this open differential and is what makes it a limited slip differential.
-Paul
-Paul
Hadoukening
Aug 29, 2016 03:05 AM
crcain
26
Aug 23, 2016 02:48 PM
nocabiwiksmx
13
May 27, 2009 09:01 PM
