Which Wiseco's for 2.4/evo hybrid swap?
I think you have been pointed in the wrong direction. Hardly any of what you said made much sense. If you are going for a 4G64 Block swap with Evo Head Wiseco makes pistons for that swap i personally have ran them. The offset of the wrist pin is a good thing in every case. What it does is keep the rod from being completely verticle at the top of the stroke. This is great since it takes less pressure to start the down stroke.
If you are trying to use a 4G63 block then you just need to get the 100mm crankshaft out of a 4G64 and get some pistons in the size of your choice. Personally i wouldn't go much over .40 over to leave room for future happenings.
BTW if you go with the 4G64 Block go with one out of a 2000 Galant. It will be a 7 bolt "same as EVO" and the engine is still the same direction.
Also call Wiseco and talk to Brian Nutter he will help you with whatever you need.
Chris
Chris
lol yea reading my own post confused me but ive learned alot more since then. i actually scored a set of custom spec pistons since then but im still want to know for the future which pistons to order incase something ever went wrong with motor.
im actually running a 4g64 block and crank from a 2000 Galant with the evo head but since you did the same swap with the same pistons did you have put them in backwards so that the wristpin offset was rotating in the right direction?
EDIT: BTW the 2000 Galant's 4G64 engine was installed the same way as the EVO engine. This is why you dont have to swap pistons around. Now if you were going to try and run a 6 bolt 64 block you might run into some of those problems. But with the setup you are talking about you will be okay
Chris
I had a 2.4 in my gsx, and which had Wisecos in 2 of my dsms and knowing what I know now, I would personally run the JE or something else than Wiseco. I had a prob with one set and the others in my 2.4 were fine as far as I know. The car is still running...I think Nothing against Wiseco, personally, just my preference now. I wouldnt build another motor w/ them though.
TTP Engineering
Evo X Dyno Results
Jan 15, 2010 01:22 PM
TTP Engineering
Evo X Dyno Results
21
Jun 16, 2009 05:11 PM
TTP Engineering
Mar 23, 2009 10:32 PM
TTP Engineering
May 29, 2008 10:09 PM
