difference between 8 and 9 turbo
If you're thinking of mounting the '06 turbo onto an '03-'05 Evo, then you're also going to need certain IX specific, ancillary bits and pieces, such as: a IX compressor housing discharge tube, a IX wastegate actuator, as well as assorted Evo IX oil and coolant feed and drain tubes.
https://secure.buschurracing.com/cat...2670c4b527323b
edit:// You'll still need a WGA. Shouldn't be too hard to come across.
Buschur makes a kit for 20G turbo installs on VIIIs. Should include everything needed for a IX turbo to VIII swap.
Quantity Part # Description List Unit Price Price
1 1310A171 Pipe,t/c Water Re $11.00 $8.38 $8.38
1 1310A248 Pipe,t/c Water Fe $11.00 $8.38 $8.38
1 1515A057 Fitting,t/c Air O $49.75 $37.91 $37.91
1 MR281085 Gasket,t/c Air Ou $3.60 $2.74 $2.74
2 MF660063 Gasket,clutch M/c $1.03 $0.79 $1.57
1 1225A042 Tube,t/c Oil Feed $10.35 $7.89 $7.89
4 MF660065 Gasket,cooling Wa $0.75 $0.57 $2.29
2 MF660064 Gasket,a/t Case $1.22 $0.93 $1.85
Subtotal: $71.02
Shipping: $9.95
