Buschur cams with a Green???
THinking on chucking a green in my car, habe an EVO 8. At the moment running EVO400 Custom Piper Cams just about the same as Piper 285's. Is it worth a cam change?? Have been looking through the forum and cant find any graphs of cars running buschur cams with a green, anyone help??
On the VIII, the higher hp cars were David's and Curt Browns, but at that time, I don't think Buschur Racing had developed their new cams yet. If you go to the ForcedPerformance.net website, you'll see the dyno charts of the Green using probably the Revolver cams. Our car is a IX, so wouldn't do you much good. Not too sure what Nievo was running on the Green, nor what Dadriva used, but you might run those posters down. They both had Greens and impressive times/dynos.
I am using 264i and 272e HKS Cams, with Fidanza Cam Gears.
I have a 2004 SSL Evo VIII.
The Cams work great for my car.
The Buschur Racing Cams should work good with the Green.
May be you will pick up some power over what you are using now.
Success .
Success .
So, what turbo are you running currently in conjunction with the custom ground cams? Have you asked Evo 400 what they think of running your current cams with the Green?
Cams that are designed to make power above 7000 rpm may not work well with a turbo that does not feed enough to the engine above that rpm to make power there in the first place
