Where do I mount this O2 for my WB ?
I am the proud new owner of a slightly used Innovate LC-1
My buddy (with a SRT-4) said you want the O2 on the hot side downstream of the Turbo but as close to the Turbo as possible, is this correct?
if you look under your car, right at the end of the xcase there is a rubber grommet in the pasenger side of the "doghouse". i just welded a bung right next to that in the 12o'clock position in the dp. works great and its a perfect place for it. right at the end of the xcase, beginning of the driveshaft and the wires will run right out in front of the passenger side of the center console.
