Engine swap question??
ok i got a 2003 lancer evo 8 im looking to do a 2.4L is the easiest way to go is a galant block and build that with the evo head... or take me 2.0 block and bore and get a stroker kit... if galant block the way to go would i search pistons for that block correct a 4g64 and the stock head bolts up and i looking to get it ported and stuff and just for time being will the stock tubro be able to run on this motor or no cause its a 2.4 now in stead of a 2.0 it would just be from home to work and never raced or stepped on
I have heard of some people using the ralliart block because all the accessories bolt in place and you can still use the serpentine belt...however, I am still unsure about the water pump issue I am looking to do this as well. I know someone here who wrecked his ralliart and said I can have his motor....So I will probably end up doing this sooner than later.....it is also said that you can use the stock evo timing belt...I too am curious as to how true these are
Howulikemyevo
46
Feb 9, 2018 10:45 PM
dephilron
Oct 5, 2016 07:38 PM
