New Forge Spring Kit today - Any advice
I bought my evo and the spring in the forge diverter valve was a little weak and has been releasing boost anywhere above around 10psi. I am recieving my spring tuning kit today and i get the basics. I just wanted to come here to ask for any advice or knowledge of experience with replacing these kits.
If anyone could give me a step by step on how to install it i would appreciate it. This will be my first work on this Evo by myself.
As far as i know its 1. remove the vacuum hose 2. screw the top off the diverter valve 3. replace spring 4. screw cover back on and replace vacuum hose. aside from that, i know to just take a few runs with the car and see how the spring works, if its too weak add a shim and test again and if its too strong move down a spring and add shims.
any help?
any help?
i recieved the kit today and replaced the springs. Im not very experienced with diverter valves but the sound to me does not sound right.. It seems to sputter when i shift/left off gas. from my understanding i should be hearing a constant and unwavering sound right? instead of a constant steady woosshh, it flutters. the boost guage WOT was reaching peak boost and backing off, is this normal?
any help?
any help?
figuerda
Jan 14, 2007 12:28 PM
turbotool
Jan 11, 2006 02:13 PM
