Built Head Questions
#31
Has anyone done flow testings on the head in these situations?
Full stock head, Stock head with +1 mm valves, mild port with stock valves, mild port with +1 mm valves, extensive port with +1 mm valves?
Post findings of any of these combinations please. (I see the one set of #'s from buschur's test of mild port stock valve, to extensive port with +1 mm valves)
#33
I don't have any practice yet, but I could have one of the good guys here look at the port and see what they thought about grinding on it. Most will undoubtedly be scared to touch it.
#34
Hey I am not arguing with Dave Buschur, or Smokey Yunick for that matter, I am only arguing with you. It´s just that they are comparing a mildly ported head to a head with "additional" porting.
Or did you find a way to isolate the gain in flow attributable to only the 1mm increase in valve diameter without factoring in the more fully massaged ports, bowls, stems and seats, eventhough you weren´t there that day, or were you?
#35
i planned to answer the OP questions, buti dont have the time at this moment.
i plan on doing my own head with +1mm int & oem sized exh valves. the valve size ratio isnt right from the factory, relative to bore size IMO.
other things limit the amount of valve size 1 can increase, shrouding by the cylinder, valve spacing between intake valves, location within the cylinder head etc.
there is a lot of work that goes into a good cylinder head. absolute flow is not what its about, there is tumble & swirl to that need to be considered.
i have seen heads that flow more than others, but lack in tumble, make less power throughout the rev range.
#36
would it be worth experimenting with mixing up the oversizes on the intake and exhaust? Like for 1 of the intake valves run a +1mm and the other (in the same cylinder) run +2mm, which would cause the intake charge to flow into the bore more on 1 side causing it to "swirl" so to say? Or am I just being stupid
#37
And that boy knows cylinder heads.
#38
For the person who asked how much lift I was looking to run here is an answer;
my current cams- BC STG 3 280's
Adv. Dur.- 280/280 Dur @ .050- 218/216 Lift- 10.80/10.36mm
1st canidate- BC STG 4 288's
Adv. Dur.- 288/288 Dur @ .050- 222/220 Lift- 11.88/12.14mm
2nd canidate- GSC S2's
Adv. Dur.- ???????? Dur @ ????- 274/272 Lift- 11.2/11.5 mm
GSC doesn't give alot of specs on their cams so I doubt if the S2's are what I will go will. The BC's exhaust cam has a TON of lift, which I havent see other cam manufactures do (make the exhaust cam have more lift than the intake cam)
#39
? every application is different & cant be summed up in 1 thread..
5) How much lift is available to be utilized on and engine setup that has had .015 milled off the block and head, using a factory head gasket? (totaling to .030 milled off. I know there isnt any valve clearance issues using BC280's with BC springs but I want to know if I can use a cam with more lift)
I know that is alot of questions, but hopefully a few of the big guys could help out with answering them. Thanks to anyone who help!
when a true race engine is built, in all actuallity, it has been assembled/disassembled ~2 or 3 times, just to verify, it has been machined accordingly & to re-check that everything is where it needs to be...and if it's not, the parts go & get machined again & rechecked, then final cleaned then assembled.
people wonder why properly built engines cost so much. it's due to the time spent verifying that everything is as expected & will live in perfect harmony @ max revs for your engine set-up.
At the end of the day, people wonder why joe-blow has a factory freak, because his assortment of parts stack in the favor of making power. all while donny ******** gets stuck with a poor mismatched, detonating engine that doesnt make squat for power.
#40
ok, so I am narrowing down my setup. so far I have; Definatly larger valves (stagard combo posible), Iconel exhaust valves, Nitrided intake valves. Stock lash adjusters.
new questions are:
Where can I get better valve guides and seats?
Are Brian Crower single coil springs W/ titanium retainers sufficent for a stroker reving no higher than 8000-8500 rpms?
new questions are:
#41
new questions are:
new questions are:
The valve on a stroker isn't moving any faster than the valve on a 2.0, so if a spring works for one it'll work on the other. I'm sure 8500 won't be a problem for them.
And as for the staggered valve thing, there's no reason to reinvent the wheel. Leave it to people with money and time.
#42
People like Aby can look at a head, take measurements, and know what to do from there. Then again, Aby has been building race engines for 20 years so it may be easier for him than others
#43
well I may just go with +1 mm on both intake and exhaust with a mild porting, new seats and guides. I know I will have to have the combustion chamber reworked to remove the imperfections caused by the broken ring land.
Is it worth it to replace the head gasket with an aftermarket one, or is the stocker good? (I am still running a stock gasket)
#44
I wouldn't say it's for the people with money and time (I'm assuming you're talking about R&D, etc.).
#45
