Spun a rod bearing...what's the worst that could of happen ?
other than having your motor completely rebuilt. I replaced my oil cooler, oil pump, and clutch when I spun my bearing. Clutch is not required obviously but i would recommend the other two items.
Got a engine for sale for cheap! But ya they are right most likely the crank and/or rods are going to be messed up. You should at least flush the entire oil system out when and if you rebuild.
Chris
Chris
Scorke
Last edited by scorke; Apr 19, 2008 at 02:48 PM. Reason: metal in the oil not oil in the system :)
