Some serious bad luck...
A few weeks back I woke up and went out to go start my car to get to school. It turned over as I expected, being that it was 45 degrees outside, I heard a loud grinding noise and my engine stopped then turned over one more time. I immediately opened the hood and discovered that my balance belt was moving and my timing belt had stopped. I took it to my mechanic and he tore it down and found my oil pump sprocket had cracked, he tried turning it and it turned sometimes and not others. He tore off the oil pump side case and found out what had happened. There is an oil syphon from the oil pan into the oil pump (which is essentially two gears that mesh together with close tolerances to the case, which pumps the oil), and the syphon has a screen to protect the pump from metal particles that could possibly be floating around in the pan. The screen had a pea sized hole in the center, I don't have ANY clue how that got there. A piece of metal passed through that tiny hole in that screen and jammed itself in my oil pump upon start-up. It was also the reason for the broken oil pump sprocket, breaking it with the force of the engine stopping from that particle. I bought the entire new oil pump side case, syphon, all gaskets, and new oil pump sprocket. The car was put back together, and turned over by hand, seemed fine, he (my mechanic), tried starting it, it got to the point where it was about to start, and the engine stopped completely. The lifters are hydraulic and once they build up enough pressure they go down farther, this is why he didn't recognize the problem when turning it over by hand. One of my valves was damaged during the initial start-up in my driveway. The valve broke off and jammed itself sideways between the head and my piston. I've been without my car for two months already. My head is at the machine shop and I'm awaiting the prognosis on that. Hopefully they can salvage it, but, I'm not optimistic. Check those oil syphon line screens! Anyone have a head they are looking to sell? I'm looking around, just incase.
If you're having problems, somebody has always got it worse. Thank you, "Evo Part-Outs" section, you make me feel better..
sorry to hear that...i have a head that i can sell..but it would cost you an arm and a leg to ship it to you..believe me..
i would go with a buschur racing head just for the f*&ck of it..
is your car modified anyway?
goodluck..
goodluck..
It's the Evo VIII has 23,*** on it.
Here's a power related mods list for the car;
HKS GT3037 Turbo kit set up on lowboost level, 22psi making 417awhp, 333tq on 92 octane, Made 526whp running race fuel at 30psi!
AEM Standalone tuned by tuning technologies
AEM wideband
Defi Boost guage
HKS 3" down pipe, testpipe, 20th ann hi-ann Hi-power exhaust
Fynetune custom shortram intake
Did have Ferrera Valves and retainers
Ported and polished head
HKS 280 Cams
ARP Headstuds
HKS Adj cam gears, HKS kevlar Timing belt
HKS T-0 turbo Timer
HKS Twin Power Dli II
HKS R-Type FMIC
HKS SSQV V2/hardpipe BOV
Snow Performance Meth Kit w/ light and 150 psi pump
Greddy 1020cc injectors
Walbro 255lph fuel pump
ACT Six puck springless clutch
dxbevo9: I should look into the buschur racing head. Have you heard anything good?
AEM wideband
Defi Boost guage
HKS 280 Cams
ARP Headstuds
HKS T-0 turbo Timer
HKS R-Type FMIC
felickz: what exactly caused the head to get screwed up?
EvolutionRacing
Jun 1, 2016 07:12 PM
hoof hearted
Oct 18, 2010 07:33 PM
anthonypazsd
Jan 31, 2010 03:01 AM
