Tale from the Dyno: ETS 'Super Value' Ball Bearing 58 Trim on VP MS109...
You'd have a much better chance of trying to run high 6s at Barona then the Q. Even there I think you will need:
1. More power
2. Less weight
3. DRs
As you know, when you get to a certain time/speed threshold it takes a lot more power to go faster. I think you should pick-up a used set of wheels, get some MT ET Drag Radials, and go see what you can do!
1. More power
2. Less weight
3. DRs
Most definitely. He already ran a 7.4 on crappy tires with his previous setup. I imagine he could have ran a 7.2-7.3 on better tires. However, he is getting into the times where it takes almost double the power gains to knock off even a tenth of a second.
Its a bit laggy....but when it hits....IT HITS! I have seen full boost @ about 4.3k in 4th gear & 4.7k in 3rd gear on pump gas...
Its missing the great low end that was possible with the green....but being that I am more of a drag racer the 513whp is more appealing to me
I will be going this Friday....wish me luck I hope the bottom end holds up and the axles stay intact
