Big Oil Leak Problem!!! Help!
Ok well i went to start my car today, and had to shut it off right away as it was poring out oil by the intake manifold on the EGR side. I took off my AMS manifold and found that it looks like its coming out of a hole (1/4) size right above the EGR port. The AMS manifold covers all this and the oil was coming though the manifold and head out the side. Im very lost on this as its never been a problem and that hole it looks to have no threads or anything... I also took off the valve cover to make sure everything looks ok under there and that seems to be ok... anyone have this problem??
well there is not much room to get a good picture. if you would look at a head you will see what im talking about, and before someone says it, its NOT a head gasket problem. its the oddest thing i have ever seen.
Problem fixed, that hole it was coming out of is sopose to have a Alen Plug in it, guess my machine shop forgot to put one back in and i didnt catch it when i put the intake manifold on. o well...
fostytou
338
Nov 10, 2023 11:55 AM
Spinsall4
Nov 26, 2007 10:43 AM
