What are the best clamps for Diverter Valve?
Just like the title says. I'm having issues with the stock style clamps either not holding pressure or breaking when trying to tighten them. I was wondering if there is a t-bolt clamp that is the size ov the DV couplers or a stronger worm clamp out there. What are you guys using & where can I find them? I can't seem to find t-bolt clamps small enough & don't know what else would work. Thanx in advance.
1 Post
Take your coupler in to Napa and have them match one of there heavy duty clamps to it. Also if you are blowing the DV or IC pipes take a little hairspray and spray inside the coupler ends put it on wet and when it dries it's like glue but can be removed with a quick twist of the pipe. I put mine on like that about a year ago. Hasn't blown off since.
Josh
Josh
Johnboy1065
13
Aug 12, 2009 06:41 PM
