Whats BETTER a KOYO or PWR Radiator?
Exactly which kit(s) are you refering to? On my Evo, with a bolton Green turbo, which has identical external dimensions to a factory IX 16G turbo and is mounted on the stock cast iron manifold, the turbo's compressor housing hit the fan shroud. So, I had to take the dremel to the edge of the shroud very slightly. Then, I had to spray that edge with black paint to protect this edge from rusting where I'd done the grinding.
Also, I had the shroud touching the UICP. The fan blades themselves didn't touch, just the outer shroud. This to could be cured also by taking the Dremel tool to the shroud, but I was too lazy to take the fan off again, so I just removed the rubber grommets in the two top mounting posts of the radiator and filled the void with black silicone and that was enough to keep the radiator from moving back toward the UICP.
EDIT: I may be the only one that's had these slight fitment/clearance problems with the KOYO. Now, in all fairness, my Koyo has functioned flawlessly by lowering coolant temps.
DTM also has a nice unit designed around a Griffin core. I'm not sure if they've posted about it on here or not. It's thin, lots of clearance, and it moves the upper hose in line with the thermostat housing so the hose is straight and away from the heat of turbo manifold. It's a nice unit that's definitely worth a look if you are considering the CBRD and other aftermarket alternatives.
https://www.evolutionm.net/forums/sh...17#post5302917
