Act clutch problem
The problem is from people who can't adjust a clutch . Or the shops that install them without adjusting it and hand the keys to the customer. It's the same as putting in a set of cams in your car and not bothering to degree them. Each car is different, some require more adjustment than others some require none.
There are people with Exedy twin disc clutches on here that have to get theirs adjusted as well but after paying $1200 for the clutch vs. $450 - $500 for the ACT single disc most aren't in here bragging about it. There are quite a few on here that have numerous launches on ACT clutches without issue.
Most people never come on here and admit that it could be them or the install, it's always the next guy. If you need a twin disk go buy one, but not every body making 350 ft. lbs of torque really needs one.
+1
I just installed my ACT HD and its been perfect, you just need to make sure you adjust your clutch, but also make sure there's enough free play left in the pedal too. Some say the best way to do it is on jack stands, but you can get away without doing it this way if you must. Check the howto section for some help on adjusting the pedal, or check out the Tech section of evomoto.com.
