4G64 Crank - Which Mitsu did it come in?
I need to order a 4G64 crank for stroker build. Which Stock Mitsubishi year and model did they come in? I've only ever seen the 4G64 reference.
I've looked through a bunch of stroker threads and never found an answer.
Mitsubishi Galant, Eclipse RS/GS and maybe a few others..
Here is a store for yah:http://www.rpmmachine.com/crankshaftkitschrymits.html
http://www.rpmrons.com/mits,cranks.html
2000-2004 I believe.
# Galant (95-98) 1993-99 2350cc 4G64 engine
* 2.4L F.I. 16-valve SOHC 4 crank kit CSMI24 - $381.08 (93-97)
* 2.4L F.I. 16-valve SOHC 4 crank kit CSMI24L - $381.08 (1998)
# Galant 1999-03, Eclipse 2000-04
2350cc 4G64 engine
# Montero Sport 1997-99 2350cc 4G64 engine
* 2.4L F.I. 16-valve SOHC 4 crank kit CSMI24 - $381.08 (1997)
* 2.4L F.I. 16-valve SOHC 4 crank kit CSMI24L - $381.08 (1998-99)
2350cc 4G64 engine
The 4G64 came in a variety of Mitsubishi cars:
Eclipse 2.4 SOHC 1996-1999
Eclipse 2.4 SOHC-16V 2000-2003
Expo 2.4 7-Passenger 1992-1996
Expo LRV 2.4 5-Pass 1993-1996
Galant 2.4 4-Cyl. 1999-2003
Galant 2.4 DOHC 1994-1994
Galant 2.4 SOHC 1994-1998
Montero Sport 2.4 1997-1999
Van & Wagon 2.4 1987-1990
you're welcome.
you're welcome.
2.4 liter 4g64 7-bolt block/crank found in 90's Mitsu Galants and others listed above. 2.4 liter 6-bolt G4CS block/crank are in alot of late 80's and early 90 model Hundai Sonata's. Both are very similar to the 2.0 4g63 block/crank with differences being a 6mm taller deck height and a roughly 80mm larger bore as well as the longer stroke crank. You should be able to find a 90's Galant block with a good crank for cheap, I bought mine a few years ago (block+crank) and had it shipped from a salvage yard in Texas for $400.
Thanks for the replies, I really don't know my old school Mitsubishi...
So which part are most guys using to build their stroker kits, 6 or 7 bolt? What's the difference between the CSMI24 and CSMI24L?
The standard Evo crank is a 7 bolt. If you want to use parts that are designed for the Evo, such as a flywheel or dual disk clutch combination, you'll be looking for the 7 bolt.
Six bolt cranks are used in 1G DSM six bolt blocks, and the 4g64 2.4 stroker blocks of that era.
R/TErnie
80
Jan 7, 2021 02:46 PM
senate6268
128
Sep 3, 2015 10:44 PM
nianlala
30
Feb 5, 2007 10:14 AM
