Twin-scroll skeptics...
#181
#183
#184
New BMW X5M/X6M/M5, 4.4L v8 twin turbo with twin-scroll turbos from Honeywell Turbo/Garrett
http://www.bimmerfile.com/2009/05/01...otor-in-depth/
#186
http://www.borgwarner.com/feature/ar...MW-Turbo.shtml
#187
http://www.turbobygarrett.com/turbob...werstroke.html
Hot damn
66mm inducer/88mm exducer compressor wheel that flows ~75 lbs/min
78mm inducer/68mm exducer on the turbine side
Must be some low grade material on the turbine housing though as they are dirt cheap.
Hot damn
#188
#189
Hot damn
Hot damn
#192
Mike, if you were building WRC cars, you'd have the NEW 997, and kept the GT3 for ****s and giggles.
Scorke
#194
The good Ni-Resist housings are expensive and still probably made in large quantities. Nickle and chromium is expensive these days.
