Twin-scroll skeptics...
Old Feb 16, 2010, 01:38 PM
  #76
joyce1bro's Avatar
Im loving my TS setup and geoff, eric and matt at full-race are the best crew around. Service is top knotch. I could not think of anyone better to deal with.
Old Feb 16, 2010, 02:02 PM
  #77
Geoff Raicer's Avatar
thank you!!! so happy to hear that you are pleased, post up pics!!
Old Feb 17, 2010, 01:08 AM
  #78
joyce1bro's Avatar
dont have any pics on my laptop right now only this one almost finished
Old Feb 20, 2010, 10:41 PM
  #79
nyquil2's Avatar
great information...i will be going with a Full Race TS manifold soon...but i will be testing it out on a BW S366
hope it works out
Old Mar 15, 2010, 01:55 PM
  #80
blackevo110's Avatar
I was pretty sure on what i wanted and got over my twinscroll itch, but now sitting in Afghanistan not being able to play with my little project, i am getting an itch for a twinscroll again. Yay...
Anyone else rocking the BC 2.4l?
Old Mar 15, 2010, 05:08 PM
  #81
Joshs EVO's Avatar
Loose that BOV. I had it and had a GT4088 TS also and it was leaking bad. Too much power.
Old Mar 16, 2010, 11:50 AM
  #82
SnowEvoVIII's Avatar
I'm definitely thinking of downgrading from a ts gt40r to a ts gt30r. Im lookin more for fast spool and a little less top end. Maybe shooting for 400ish whp and 350tq? is a spool in the mid to low 3s possible on a 2.3?
Thoughts?
Old Mar 16, 2010, 12:34 PM
  #83
since you had a twinscroll 40R you can swap to any T4 twinscroll turbo -- there are borgwarner options worth considering bu i am not sure if that twinscroll 30R would do the job
Old Mar 16, 2010, 01:43 PM
  #84
What you you recommend switching to to get the quickest spool possible? Being here in CO im more concerned with power through turns and quick spool than top end laggy straight line power.
Old Mar 16, 2010, 02:41 PM
  #85
sabastian458's Avatar
the 30r will be insane with a 2.3, as that is what my old car's set up was. On a very near limits it was 460hp and 430+ tq.
Old Mar 16, 2010, 02:52 PM
  #86
When did she reach full spool?
Old Mar 16, 2010, 03:39 PM
  #87
scorke's Avatar
Not his setup but they were pretty similar.
Made full boost (32 PSI) at 4800 rpm.
Scorke
Old Mar 16, 2010, 03:58 PM
  #88
If i were cruising in the 4k range, it would go full spool almost instantly (500-600) RPM when going to WOT.
My last log that I took before selling it, at 2300 rpm and -5.4psi, 23.5 throttle position I went WOT. The first reading of 100% throttle was at 2500 rpm and .791psi. And I hit 28.5 psi (max psi at that time) at 4650 rpm.
On average the boost curve was 1500 rpm. Full boost was hit by 4000-4500 rpm depending on where in the rpm band I started the WOT pull.
Old Mar 16, 2010, 03:59 PM
  #89
Scorke
was this on the first manifold or the cast SS one that we both ran?
Old Mar 16, 2010, 04:08 PM
  #90
jid2's Avatar
Twin Scroll T4 35R seems like a really nice option, and the new BW stuff is tasty as well. If I needed more power, or was starting a build now that's what I would do for sure.
For now my 2.3L and GT30R does what I need on E85.
Boost at 24 psi by 4050 on pump gas.
28 psi by 4200RPM on e85
28 psi e85 power graph
Quick Reply: Twin-scroll skeptics...
