Rapid Cylinder Wear??? w/pics
#32
.020" * 25.4 = .508 mm + 85mm = 85.508 mm
Now you measured your bore to be: 85.471 mm
Which means the piston is larger than the bore, so that is not working out righy. Contact Ross and ask them the actual size of their 20 thou over pistons are. Or ideally measure the ones you have.
How did you measure the bore?
#33
Well using some math, stock 4G63 bore size is 85 mm, adding .020" to that gives you:
I measured them with a dial bore gauge.
#35
Where are you measuring the bore? You will get different readings at the top, bottom and middle of the cylinders. Measurements will also vary if you measure across the bore or from top to bottom. This is because of how the piston rocks in the bore and wears different spots more or less.
#36
#37
oh well, I guess I'll figure it out someday if it was wearing out prematurely or not, because I just put the head and timing belt on. hopefully it'll be ok. I didnt see any scuffs or anything that the side skirt of the pistons would've made. I actually had a friend that works in a machine shop come out and measure the bore. yeah he set the dial bore gauge first with a micrometer.
#38
supraturbo680
108
May 1, 2008 07:53 PM
