Baffled muffler so the cops will shut up?
Old May 20, 2008, 02:00 PM
paintballproam's Avatar
So the cops where i live are cracking down on mufflers/exhaust. NH inspection says you need to have a muffler with a baffle. I have a Megan exhaust with a straight through muffler and ive gotten away with a warning a few times. I just dont want to restrict my exhaust flow by going with a typical flowmaster style muffler. What are your suggestions?
Old May 20, 2008, 02:06 PM
Ph3n1x's Avatar
You can drive with the car off an they will still stop you for anything that looks aftermarket. Cops are dicks.
Old May 20, 2008, 02:09 PM
its not the sound that matters, its the fact that its a straight through, i can get a ticket for it
Old May 20, 2008, 02:10 PM
4WS Tuning's Avatar
The cobb exhaust has a very "stockish" look and sounds great.
Cheers!
Old May 20, 2008, 02:11 PM
Ph3n1x's Avatar
Cheers!
That or the Fuitsubo.
Old May 20, 2008, 02:15 PM
i just dont want to give up performance
Old May 20, 2008, 02:19 PM
Ph3n1x's Avatar
If you go with a quiet exhaust most you lose is a couple HP. ITs only when your running for most HP possible will it acutally hurt you.
Old May 20, 2008, 06:53 PM
EMonz57's Avatar
yea dude I was the same way when I had that Evo. You know what I decided? that the few HP youl lose you wont even notice and it is worth more than to get tickets or worry about the po po every time you take that car out. not only that but that car needs some serious sound change becuase it is retarded loud and pretty raspy too under heavy load with that setup
Old May 20, 2008, 07:01 PM
chefnevo's Avatar
there is the Apexi noir stockish & stealthly has good flow to. There are guys that have made good power with them.
Old May 21, 2008, 02:52 AM
Well i put a cat on it and its not as bad. since you originally did the exhaust, do you know what i can do to use the most of my existing exhaust as i can? Ive got a local exhaust shop, but they usually only do like flow master and magnaflow.
Old May 21, 2008, 05:56 AM
igo4bmx's Avatar
get two resonators installed on your megan exhaust.
my car is so much quieter with mine installed
also it looks like you're baffling more than you need to
Old May 21, 2008, 06:01 AM
ForcedFedRS's Avatar
I live in NH, and I've been ticket free with all of my exhausts. No warnings either. I'm currently running a Buschur 3" with a magnaflow and no problems yet. Wonder why you get hassled so much.
Old May 21, 2008, 06:06 AM
You can get a Vibrant race muffler and put it down stream to quiet it down, maybe two if you need. I've looked into the option for awhile and I'm still thinking of doing it at some point. A local dealer/ installer for the Vibrant stuff in NH is Synaptic 3 Engineering in Candia. www.synaptic3.com
Old May 21, 2008, 06:40 AM
EMonz57's Avatar
just change the muffler. but I was going to just toss under to resinators and call it a day. No matter what that car will be F ing loud though.
Old May 21, 2008, 06:54 AM
dpacific's Avatar
Megan type 2 (stealth flatblack) ftw
Quick Reply: Baffled muffler so the cops will shut up?
