My HTA37r Buschur Pump Gas Evo
#136
Correct...you adjust the shock body up and down inside the lower piece that bolts to the hub. This allows you to adjust ride height without affecting spring preload, which is what David said about moving the spring collar up till it touches the spring, then giving it one more full turn.
#138
1 Post
I have installed ALOT of coils before but never a jap setup like this
Koni, Bilstein, and H&R here
#141
1 Post
Ok well I got the ride height adjusted pretty close. The rears need to come up about 1/2 and inch and the fronts need to come down about a 1/2.
I got the new tires installed, and 2 stepped the car 1 time. All I can really say is OMG this sh*t hooks
I am so freaking sure this car will go 9's at 150 with everything I have done
All I need is Dave to do an alingement tommarrow for me? My machine at work is old school and the beams will not go all the way around
Indy drag springs installed on the Apexi N1 coils...
Front
Rear
And the new Taller/Wider softer tires...
Front
Rear
#143
looks good Jeff!!!
but don't you think the rear seems to be lower than the front?
Isn't that when you launch you will distribute the weight more in the front?
I'd lower the front if its just me like those procco Evo's.lol
#144
Jeff said he had to raise the front and lower the rear.....
I don't think I can get an alignment on your car tomorrow. I am going to be buried on a car that HAS TO GO tomorrow, customer has been waiting on week on a HUGE job.
If you are going to be up here I can try to work you in but it will require you getting dirty helping.
#145
1 Post
yes it was my phone sorry man
I can get dirty.... I wanna race damnit
I get out of work at 12, so I proly wouldnt be there til 3ish? thats proly to late man?
#148
Let me know for sure if your going Sunday, if so I'll be there. Is it bracket racing that day?? I don't care either way. I just wanna see what I can run with the new tune. If you go Sunday I can record your 9 second pass in High Def for ya
