All Different Evo Turbo Options (Turbos, Specs & Feedback)
Let me start by saying that if this is a repost, I apologize.
I want to compile a resource of different turbo options, specs and feedback. This is the tentative format list:
__________________________________________________ ____________________________
-General Turbo Name/Type: (FP Green etc)
-Companies that offer this turbo and their variations on it: (For example: ETS HTA35R)
-General Specs: Sizes etc
-Typical HP range:
Pump Gas:
Race Gas:
-Price(s):
-Needed none basic supporting mods:
-Spooling Characteristics:
-Optimal RPM:
-General Opinions/Synopsis:
-35R
-AMS GT35R
-Typical HP range:
Pump Gas:
Race Gas:
-Price(s):
-Optimal RPM:
-General Opinions/Synopsis: Jesse@DogboxRacing: "i went 125 on pump meth at 480hp on gt35r stock ecu"
-37R
-AMS GT37R
-Typical HP range:
Pump Gas:
Race Gas:
-Price(s):
-Optimal RPM:
- GT3582R
-Garrett
-Turbine Housing: T3
Turbine Inducer: 68mm
Turbine Trim: 84
Turbine Exducer: 82mm
Turbine A/R 3 options
Compressor Exducer 81.5mm
Compressor Trim 56
Compressor Inducer 61mm
Compressor A/R .70
Ball Bearing yes
-Typical HP range:
Pump Gas:
Race Gas:
-Price(s):
-Optimal RPM:
-PT6776R
-Precision
Turbine Housing T4
Turbine Inducer 74.2mm
Turbine Trim 78
Turbine Exducer 84mm
Turbine A/R ???
Compressor Exducer 84mm
Compressor Trim 63
Compressor Inducer 66.6mm
Compressor A/R ???
Ball Bearing yes
-Typical HP range:
Pump Gas:
Race Gas:
-Price(s):
-Optimal RPM:
-FR T3/T67
-Full-Race
Turbine Housing T3
Turbine Inducer 67mm
Turbine Trim 76
Turbine A/R 2 options
Compressor Trim 63
Compressor Inducer 66.7mm
Compressor A/R .70
Ball Bearing yes
-Typical HP range:
Pump Gas:
Race Gas:
-Price(s):
-Optimal RPM:
-GT3076R
-Garrett
Turbine Housing T3
Turbine Inducer60mm
Turbine Trim 84
Turbine Exducer 76mm
Compressor Exducer 76.2mm
Compressor Trim 56
Compressor Inducer 57mm
Compressor A/R .60
Ball Bearing yes
-Typical HP range:
Pump Gas:
Race Gas:
-Price(s):
-Optimal RPM:
-57trim
-ETS
-Typical HP range:
Pump Gas:
Race Gas:
-Price(s):
-Optimal RPM:
-General Opinions/Synopsis: SickSilverNLow: "I got the ETS 57 trim and on pump gas 92 octane with moderate timing and A/F, we got 402 whp on 24 psi. The car is awesome to drive. The turbo is actually a real shiner when using pump and meth or race gas."
-Typical HP range:
Pump Gas:
Race Gas:
-Price(s):
-Optimal RPM:
-35R
-AMS GT35R
-Typical HP range:
Pump Gas:
Race Gas:
-Price(s):
-Optimal RPM:
-37R
-AMS GT37R
-Typical HP range:
Pump Gas:
Race Gas:
-Price(s):
-Optimal RPM:
- GT3582R
-Garrett
Turbine Trim: 84
Compressor Trim 56
Compressor A/R .70
Ball Bearing yes
-Typical HP range:
Pump Gas:
Race Gas:
-Price(s):
-Optimal RPM:
-PT6776R
-Precision
Turbine Housing T4
Turbine Trim 78
Turbine A/R ???
Compressor Trim 63
Compressor A/R ???
Ball Bearing yes
-Typical HP range:
Pump Gas:
Race Gas:
-Price(s):
-Optimal RPM:
-FR T3/T67
-Full-Race
Turbine Housing T3
Turbine Trim 76
Compressor Trim 63
Compressor A/R .70
Ball Bearing yes
-Typical HP range:
Pump Gas:
Race Gas:
-Price(s):
-Optimal RPM:
-GT3076R
-Garrett
Turbine Housing T3
Turbine Inducer60mm
Turbine Trim 84
Compressor Trim 56
Compressor A/R .60
Ball Bearing yes
-Typical HP range:
Pump Gas:
Race Gas:
-Price(s):
-Optimal RPM:
-57trim
-ETS
-Typical HP range:
Pump Gas:
Race Gas:
-Price(s):
-Optimal RPM:
I applaud your effort, but must say I don't think this list will go anywhere. There are probably literally THOUSANDS of options, when you consider different A/R's, manifold options, twin vs single scroll, standard vs HTA, Garret vs Precision vs Turbonetics and such of all these turbos.
Probably be able to use the "search" option and be able to look for what specific purpose you want your car to be and narrow it down. But like what Pirate said, the possibilities are endless.
Drag racing applications:
1.X turbo
info etc....
2. x turbo
info etc...
Road racing applications:
1. xturbo etc....
If not going into real specifics then maybe just general info about the turbo and which application of racing / daily driving it would best be used for. Then people can search for more detailed info about the turbo in interest.
It still might be a huge post but with a lot of info though. Then we can sticky this and hopefully people can see the sticky before starting a new thread.
Why not have people just start filling in the blanks instead of deciding what will and won't work? The search function works great but all the info being requested is spread over a **** ton of individuals threads.
This was a thread from a while ago that might add to this but still does not really address your questions:
https://www.evolutionm.net/forums/sh....php?t=283592&
Code:
Garrett Precision Full-Race Garrett GT3582R PT6776R FR T3/T67 GT3076R Turbine Housing T3 T4 T3 T3 Turbine Inducer 68mm 74.2mm 67mm 60mm Turbine Trim 84 78 76 84 Turbine Exducer 82mm 84mm 84mm 76mm Turbine A/R 3 options ??? 2 options 3 options --------------------------------------------------------------- Compressor Exducer 81.5mm 84mm 84mm 76.2mm Compressor Trim 56 63 63 56 Compressor Inducer 61mm 66.6mm 66.7mm 57mm Compressor A/R .70 ??? .70 .60 Ball Bearing yes yes yes yes
bump for updates.
Even if each person just contributed a SMALL amount of information, we could compile a general list with some general information for ppl to reference.....
Bump, over a year later and i still think this is a good idea. lol. And I'm doing a turbo swap this winter and need to start preparing. HTA35R = street beast?? I'd know if everyone just contributed a very little!
We have it for rims, cams and other stuff, why not the one thing we're all here for?? TURBOS!
