Finally, an Offical Evolution 02 DUMP!!!!
The O2 dump isn't the same thing as a QTP cut out. If you look at a turbo you'll see the wastegate flapper (on the left in the pic)
![](http://i26.photobucket.com/albums/c125/samemory/Buildpics002.jpg)
The O2 housing just dumps the gases coming from the internal wastegate, so they don't get mixed up and create turbulence. So for power gains, if you don't have an aftermarket exhaust, the QTP cutout would be more beneficial, but doing both at the same time would be better
![Big Grin](https://www.evolutionm.net/forums/images/smilies/biggrin.gif)
im number 7 on the list , they have great customer service, and they were very patient in making the part, they made so it would make power , they could had sold there first protoype , but they made a 2nd then with the first and 2nd they ended up going back to the drwing board and making there version been sold right now, they stand 100% by there product and did dyno test also .
great work guys !!!!!!!!!!!!
You sure you got the first one? b/c couple weeks ago I was at a shop, there was a customer there to have his O2 dump installed, and he told me he bought it from evopowermods.com and that's how I came to know O2 dump is being made for evo.
according to my tuner, it is only worth 5hp compare to the aftermarket o2 housing.
The cut out sits on the downpipe, it opens and basically bypasses the entire exhaust. The Dump above divorses the exhaust stream from the wastegate stream. The Cutout is an equivalent of taking your entire exhaust off.
This seems like a great idea, simple solution to an exhaust turbulance problem. How come no one else has done this yet, any unexpected problems? Is the install any more difficult than a typical tubular O2 due to the seperate dump adding size? Where does the gas exit from the dump?
Right off the bottom of the car. It just dumps straight down.
Thanks for the info.
My concern is if there is only minimal gain comparing to the ebay O2 housing, then $250 is not worth it (for stock turbo)
After market O2 housing has the similar purpose as the O2 dump since the diameter is bigger than stock, resulted in less back pressure.
But if I didn't upgrade the O2 housing then I would have gotten the O2 dump instead since it functions better.
If anyone is upgrading to O2 dump from after market O2 housing, please post your comparison results.
I could see that, however I remember Al tuned a car with a custom one and from what I remember he could give the car more timming. I know it has to help with heat control and lower EGTs. Im sure in the right application (FP Green) or something like that with 400+ WHP it could offer a lot more power than a Megan ect.
I will have mine on soon
