Finally, an Offical Evolution 02 DUMP!!!!
Old Jun 11, 2008, 09:39 PM
  #46
High_PSI's Avatar
Originally Posted by 11secMR
yeah thats how mine has been modified from ics it is completly divorced from the rest of the housing. But no matter enjoy ur dump and im sure u will be happy whne its on
Yours leaks a little right? You feel a slight exhaust pulse at idle from your modified Megan dump?
Old Jun 11, 2008, 10:04 PM
  #47
sparky's Avatar
Originally Posted by High_PSI
....If you use an OEM gasket, it is open in the center and you will most certainly have leakage between the exhaust and the wastegate exit if you modify the Megan 02 into a dump.....
As a practical matter, wouldn't you experience identical crossover "leakage" if you were to use the OEM gasket in conjunction with the Evopowermods dump setup? The leakage then is due to the OEM gasket design. So, unless I'm missing something, the Evopowermods flange is not immune to the same crossover flow, if used with the OEM gasket.
Old Jun 11, 2008, 10:37 PM
  #48
High_PSI's Avatar
It doesn't use a gasket, so no, it does not. if for some reason you DID use an OEM gasket with it, then yes it would leak.
Old Jun 11, 2008, 10:48 PM
  #49
sparky's Avatar
I want to further discuss it with you, High PSI. However, first I'll go downstairs and reload the Coronas.
Old Jun 11, 2008, 10:54 PM
  #50
TalonTuner4G63's Avatar
I take it they have taken so long due to fitment issues with the factory undertray? DSM guys have been running these things for years now.
Sound from 02 dump is awesome. Not quite as good as an external wastegate, but pretty damn close!
Old Jun 11, 2008, 11:00 PM
  #51
High_PSI's Avatar
The Undertray is no big deal, seiously, 2 second modification, done. Not even a hole, just cut away a tiny snippet, done.
Old Jun 12, 2008, 12:41 PM
  #52
11secMR's Avatar
mines not a megan its a helix and my little leak is an easy fix either way and i know why it leaks. But u dont even hear the leak over the HKS 280 idle so it doesnt really matter. Either way glad u got it on and u can feel the differance i have been tellingu about
Old Jun 12, 2008, 01:25 PM
  #53
wshihdnevo's Avatar
JMF has had one out for awhile now too.
Old Jun 13, 2008, 09:37 PM
  #54
High_PSI's Avatar
OMG I just took a trip from NJ to VA. Scared SO many people on the way down. Otherwise it is silent and isn't a nuisance until WOT.
It is LOUD, I mean LOUD, no question about it. Boost/Tune didn't change. Just makes boost more consistant and less drop off. Don't forget that I had a Megan 02 before which flows quite well. If you have a STOCK 02, you will see more boost for sure, especially if you are nearing the limit of the stock turbo.
I just got a Video Camera, some vids SOON, I promise
Old Jun 13, 2008, 09:40 PM
  #55
SpunEvoIX's Avatar
i always wanted that when i had my stock turbo setup!!!!
Old Jun 16, 2008, 08:37 PM
  #56
High_PSI's Avatar
Old Jun 16, 2008, 08:45 PM
  #57
evoDON's Avatar
just ordered mine a few days ago. got version #2 cant wait till its sitting on my door step and i can install it
Old Jun 16, 2008, 08:52 PM
  #58
mpevo8's Avatar
that video ! lmfao. sounds awesome but WTF was that when you were yelling. lmao.
Old Jun 16, 2008, 08:54 PM
  #59
High_PSI's Avatar
It was just so loud and I pissed off so many people at once. Gave me reason to celebrate. It was beyond loud, that's all you could hear.
Old Jun 23, 2008, 07:44 AM
  #60
nitz's Avatar
Originally Posted by dbsears
What setup is that?
that's what the uk boys like to run. there are a few sources but this one is from www.evo400.co.uk
Quick Reply: Finally, an Offical Evolution 02 DUMP!!!!
