mivec cam install / problem
I have seen several instances of the mivec cam being installed improperly. Just because the timing marks on the gears line up with the valve cover doesnt mean the timing is correct. If the cam was not installed correctly in the mivec cam gear, there will be issues.
remove the mivec cover again (4 bolts) and the 14mm head bolt. Look into the cam gear and see if the pin in the cam is in the hole in the gear. My guess is it is not aligned correctly.
