SS Bolts for Exhaust Manifold
Old Jun 12, 2008, 04:09 PM
BGR
BGR's Avatar
You guys rule - thank you (a mini project this weekend )!
Old Jun 12, 2008, 05:40 PM
travman's Avatar
I run these.......the 2G and evo are the same.
http://ssstuds.com/
Old Jun 12, 2008, 05:59 PM
EatSleepBoost's Avatar
yup. 2g's and evo's are very similar in all aspects (crankwalk)
Old Jun 12, 2008, 07:42 PM
BGR
BGR's Avatar
Thanks travman, but I didnt see any bolts. Maybe I missed them - I only need 4 for the top of the heatshield. Do you have any extra on hand?
http://ssstuds.com/
Old Jun 12, 2008, 09:12 PM
VRSF Tiago's Avatar
If you're going the home depot route make sure you get grade 10.9 bolts. That's what the OEM bolts are made from and will be less likely to break in the future.
Old Jun 12, 2008, 10:35 PM
hytek369's Avatar
good tips here
Old Jun 13, 2008, 08:32 PM
BGR
BGR's Avatar
^+1..love EvoM
Old Jun 13, 2008, 08:42 PM
rush63's Avatar
Originally Posted by BGR
I just want the bolts that hold the heatshield down. Any other place I can look for little cheaper? Or should I just buy new ones from dealer and replace when they get rusted again?
Oh, in your first post you're asking where to buy stainless steel studs for the exhaust manifold
Old Jun 13, 2008, 08:47 PM
BGR
BGR's Avatar
fixed...
Old Jun 14, 2008, 11:43 AM
travman's Avatar
Sorry dude misread your post - thought you were looking for studs for the exhaust manifold, not the bolts that hold the heat shield down.
yes go to a hardware store or if you know the size/thread/etc you can get stuff from mcmastercarr.com as well
Old Jun 14, 2008, 05:32 PM
BGR
BGR's Avatar
Not a prob! I guess I'll take the stock one with me and match...I'm sure they'll have something there. Thanks.
Old Jun 14, 2008, 05:45 PM
phabaznbro's Avatar
yeah i don't see why they wouldn't..gl though..i actually just changed mine to the ARC piece and will likely do the same..
Old Jun 14, 2008, 06:19 PM
jmelocik's Avatar
Those bolts that hold the heat shield down are 8mm x 1.25. They are also called M8-1.25. You will need the ones that are 16mm in length, any longer and they bottom out before contact with the heat shield which creates a nasty rattle! Ask me how I know. Check out this link:
http://www.boltdepot.com/product.asp...&cm=19&cd=1245
I hope this helps.
Josh
Old Jun 15, 2008, 10:50 AM
BGR
BGR's Avatar
Josh, thanks so much!!!
I hope this helps.
Josh
Old Jun 16, 2008, 10:16 PM
hytek369's Avatar
thats really cheap
haxr303
Jun 4, 2018 08:16 PM
dsevo
Sep 21, 2008 07:03 PM
blackonblackevo
May 10, 2007 06:59 PM
mikiblueeyes
18
Nov 23, 2005 06:45 AM
rpm-evo
Jun 4, 2004 01:21 PM
Quick Reply: SS Bolts for Exhaust Manifold
