If i was to upgrade my internals on my evo motor would i be able to run 30+ psi on 93
If you go with meth or even try high boost on pump, you will need rod bolts. Too many failures these days and i think its high boost + high revs + mediocre tune= KABOOOM.
I am not a special case, but running 30psi on a total stock bottom end on pumpgas (92 here as well) takes alot of dedication, time, and some EGT sacrifices.
Properly upgraded internals take pretty much anything you throw at it unless you're going extreme with a large frame turbo pushing more than 50+ pounds of boost.
The amount of air flow measured as cubic feet/min varies greatly among different turbos and you cannot just conclude 30psi is 30psi no matter what turbo because different turbos flow different cfm even at the same boost pressure.
You are somewhat right on the stock turbo part though.
Didn't see much info . But assuming you plan to run an after market turbo.
Building it makes it stronger... yes, but like a few said depending on the turbo and how much air it flows at x psi will make a big difference.
Also depending on the turbo you may need better octane or meth/alky. Or pull all the timing out and make the same power as a properly tuned car at less boost.
So technically you can run 30 psi. Should you will depend on your setup.
THIS is the dumbest thing ive ever heard... you know your advice could cause this guy to blow his engine!
if you dont know what ur talkin about y even post!
The turbo doesnt matter! 30 psi is 30 psi! some turbos just engage later!
and you will need to run meth/alchy inj to hit 30 psi..
you could do it with a good meth kit and run it on the stock block with stock internals.. no ned to upgrade internals since u still wont be able to on pump
I think it depends on all sorts of factors... you have to remember that boost is simply a measure of resistance. You have a bottom end, cylinder head, cams, intake and exhaust manifolds, turbine housings, exhaust system, etc to consider.
Running 30 psi with a setup where all of the above is not so great is absolutely nothing compared to 30 psi where all of the above is great, given the same turbo.
I think on a nice setup, running 28-30 psi on a stock turbo can be done no problem with 93 octane. They have been doing it in the UK for years and years and their fuel is around 93 in the states.
But don't get fixated on boost.. get fixated on how your engine is breathing.
The question you asked was, "If I was to upgrade my internals on my EVO would I be able to run 30+ psi on 93."
Rather than get involved in all the misinformation that has already been put in this thread let me just answer your question.
Yes, based on JUST the fact you are upgrading the internals you could run 30 psi of boost on pump gas. That answers your question but leaves too many other things "open".
A few things. The stock internals can also run 30 psi on pump gas and not blow chunks on the highway.
Next, the tuning is important but I honestly don't feel they are as important as the the parts choice.
Running 30 psi on straight 93 on the stock turbo is much harder to do than it is to run 30 psi on a GT35r.
You also need a good head, cams, FMIC just to name a few.
30 psi is not 30 psi!
Not true. With a good setup and good tuner it's not really a problem.
I run 32psi on my stock turbo. BUT I am running 100% METH and it isn't a steady 32psi it's only a spike. That where my 423TQ comes in. When all said and done make sure you get a good tune bro.
An interesting point to remember... why does a GT35R make more power than stock turbo at the same boost pressure?
The answer is primarily because the exhaust manifold and turbine housing are larger which means you reduce exhaust back pressure which means your engine is breathing much better. This means that X psi of boost (resistance) yields a lot more flow with GT35R versus stock turbo.
Other smaller issue, but still a added benefit is cooler intake charge... I think this is because of two things, one the compressor housing is larger, so less heat gets soaked into the charge air, and secondarily, since there is more overall air flow which I think might mean velocity and therefore air moves quicker through the hot turbocharger.
Some of the above is speculation so correct me if I am wrong.
