Again...Which turbo should I go with?
Once again I have another debate on which turbo I should go with. I had decided to go green but I ran into another turbo kit that uses the stock manifold. The ATP 3076R Stealth Kit. Does anyone have any information on this kit vs the FPGreen. I kinda know which way I want to go but also want to know what you guys think so...
ATP 3076R BB Stealth Turbo kit or FPGREEN
no atp, youll be sorry if you get that.
go green youll be happy. if your worried about making more power, get hta35r...
http://www.youtube.com/watch?v=6kmnOrUopXU
look at how fast the 35 spools, and we know its capable of over 500hp. i see no lag with it.
but if you dont want to go that big, get the green. dont go with a 30 you will regret it. the green is a monster, spool at any rpm thats drivable. and good power too. for a stock motor its unbelievable.
but id still go with the hta35, but go green otherwise.
The spool on the 76 is after 4000rpm the lag is not worth the extra 50HP.
The only benefit the GT3071r will have over the green is a less restrictive Hotside and potentially better exhaust gass flow at high RPM...
Green and the HTA35R are the most recomended Turbos on this forum, they do need significant supporting mods to run effeciently though so may not suit everyones needs...
Good Luck
If you'd like the benefits of a tubular manifold and larger turbo combination such as the GT3076R but still want to retain the stock look, Speed Element in CA has been able to adapt the stock manifold cover to our Super Value Turbo Kit. The new redesigned SV manifold is even lower profile, making that even easier. Here's a picture of our latest manifold design:
And the kit on our site - http://www.extremeturbosystems.com/M...duct_info.html
Tom
Tom
