Stock Engine FP Green 93+Meth Dyno Results
Today, I hopped on the dyno to finish tuning the Shameless Tuning Evo IX to see how much I could get out of the Aquamist HFS-1 kit, spraying 50% VP M1 Meth and 50% Distilled water.
The car previously made 350whp & 330lb-ft and trapped 120mph on straight 93 without the meth, @ 26psi.
Still running 93, the only change was the meth kit, and it made 392whp on 3 consecutive pulls, and then reached its limit at 393whp & 365lb-ft @ 30psi, tapering to 26 at redline, logging 46lb/min of airflow.
ACT Xtreme Street Disc Clutch Kit
Fidanza 9.5lb Aluminum Flywheel
Helix 3" Downpipe
3" Test Pipe w/ 3" QTP Electric Cutout
AGP FMIC
Nisei LICP
ETS Intake & UICP
Walbro 255 Fuel Pump
Precision 780cc Injectors
PPI Ported/Coated 02 Housing, Exhaust Manifold, Turbine Housing
Forge 20psi Wastegate Actuator & #65 boost pill
Crushed IX BOV
FP Evo Green Turbo
Aquamist HFS-1
ARP Head Studs
Shameless Tune
Engine, cams, boost control solenoid, plugs, plug gap are all stock
(Click pick for larger version)
Helix 3" Downpipe
AGP FMIC
Nisei LICP
ETS Intake & UICP
Crushed IX BOV
FP Evo Green Turbo
Aquamist HFS-1
ARP Head Studs
Shameless Tune
Helix 3" Downpipe
AGP FMIC
Nisei LICP
ETS Intake & UICP
Crushed IX BOV
FP Evo Green Turbo
Aquamist HFS-1
ARP Head Studs
Shameless Tune
Helix 3" Downpipe
AGP FMIC
Nisei LICP
ETS Intake & UICP
Crushed IX BOV
FP Evo Green Turbo
Aquamist HFS-1
ARP Head Studs
Shameless Tune
Best bolt-on turbo. Once he gets those cams, he's maxed out @ 30PSI i would guess. Great for a daily driver/stock block, but if you want to go bigger someday, you still have to buy an entire turbo kit, whereas if you got something like a 30R right now, you could always upgrade to a 35R later. Just my opinion. Still nice numbers on the green
