Problem with Zaklee Clear Cam Gear cover
#47
Mishi -
I appreciate your efforts here. If the cover is put on with "light screwdriver-level" torque, the head can expand and contract without stressing the bushings. By the way, I have a new Instruction Sheet that I put in all clear cam gear covers now that addresses this. Thanks!
- Rob@Zaklee
- Rob@Zaklee
#49
I just purchased one of these, and look forward to getting it on there. I learned the hard way about over tightening with the plastic cover on the valve cover. Had a thought though. They do sell rubber or nylon washers at the local Home Depot. Has anyone tried putting those in between the cover and the bolts? Just a thought.
#50
Any particular reason you want to be able to see your timing belt go round and round?
#53
Seeing your after market cam gears, being able to see if the belt is starting to wear funny, having something different then every other Evo that came off the assembly line. These are just a few reasons that I purchased a Zaklee clear cam gear cover. Is it made of different plastic than the OEM one? Obviously it's different, It's clear! LOL It's made from Polycarbonate not ABS plastic, although both are very durable in there own right, they both have certain down falls. The OEM one can turn white or grey from certain chemicals. The clear one can become cloudy from chemical like chlorinated brake parts cleaner. Why would I purchase another one? Because of the incredible customer service after the sale. If it was for nothing else that alone would be enough.
Josh
Josh
FS[SouthEast]: Zaklee Evo 9 Cam Gear Cover
hutch959
Jan 1, 2017 04:45 PM
FS[Northeast]: NY: Evo VIII Zaklee Clear Cam Gear Cover
MisUnderStood
Dec 5, 2016 05:47 AM
THmotorsports
89
Nov 16, 2015 03:28 PM
robert5995
Evo 'For Sale' Exterior Styling
123
Oct 30, 2009 05:36 AM
