BR's dyno testing and new parts development continues...
Dave did you ever see positive pressure in the intake pipe? Like on lift off?
And maybe I did not read it right... but it sounds to me like the main difference with this catch can is it has 3 ports to it? Or does it have some baffling or filtering or something else that distinguishes it from your run of the mill catch can?
This is happenstance that Buschur is doing some research on catch cans because I am currently in the market for one. I was just about to buy the Greddy one when I saw this thread. I'm very interested in the results and the price.
Standing by.....
Standing by.....
in fact me and my buddy planed on making one out of carbon fiber.
Dave, I there is a guy on here with a product you NEED to try with this. His username is s2kracka and he has a product he calls Kracka Vents; they're basically one-way check valves for the lines as they leave the valve cover, and they help increase the vacuum in the valvecover and crank case but not allow boost pressure back into them. PM me or him for details, i do not want to clutter your thread.
Here is the product Scheides is referring to. I sell them through Modern Automotive Performance (an EvoM board sponsor) so if anyone is interested please either contact them or myself for more info. MANY DSM's, Evo's, and S2000's are already running these and all are reporting back great results. We plan on putting them on MAP's 4G63-powered FD RX-7 the next time it goes up on the dyno to see what kinds of gains we're able to get from these vents alone. This is the white one that was at the Buschur Shootout last year, and should be in attendance again this year.
http://www.maperformance.com/store/p...cat=695&page=1
![Big Grin](https://www.evolutionm.net/forums/images/smilies/biggrin.gif)
Best way to clean an intercooler that is already dirty is go to Home Depot and buy a gallon of Greased Lightning, take the intercooler off, wash it out and let it drain. There is a thread on here from a few years ago that is in detail I did.
A belt driven vacuum pump isn't anything I am going to mess with. I have used electric pumps in the past and the work OK too.
My idea of the perfect catch can would be, two lines which are direct fit/replacement for the PCV back outlet and side outlet nipple. Then the lines would have a vacuum applied to them, and there would be a guarantee that no actual oil would go into the intake tract. And that nothing could ever enter the valve cover outlets unfiltered.
The valves that have been posted in MY thread about catch cans are one way check valves like a PCV correct? Which allows the breather to be attached to a boost/vacuum source to pull a vacuum under vacuum conditions and not push boost into the engine under boosted conditions, correct? If not please explain what the purpose is.
crcain, on lift off there still was not positive pressure although the pressure rose slightly, it was still in the negative numbers. The can actually has four ports on it. Two for the valve cover ports, one for the port that goes to the turbo inlet and one for to return the oil to the engine. The inside of the can also has a seperation canister inside of it so the oil doesn't get sucked into the turbo.
