Installed Forge UNOS MBC!!!
As the title says...I just installed a Forge UNOS MBC!!! I ran the lines from the WGA and t'd into the BOV...
it feels GREAT! steady boost at 21psi all the way to redline!!! the power gain is amazing!
the install was striaght forward...ill sum it up in some simple steps...
step1- take off upper ic pipe and intake(unplug MAF).
step2- remove all stock vacuum lines.
step3- cap the nipples on the boost control solenoid(BCS), intake, and compressor outlet.
step4- connect new vacuum line from wastegate actuator(WGA) to side nipple on MBC, "T" the vacuum connection on the BOV and run a line to the bottom nipple on the MBC.
step5- find a place to mount the mbc. I mounted mine on a bolt that holds the fan to radiator.
step6- take it out for a spin and re-adjust the mbc to your desired boost level.
step7- ENJOY!
and for people confused with how i installed it i made a before and after pic...
BEFORE:
AFTER:
happy boosting!!!
I do have a question though...
how many "clicks" = 1psi of boost?
step7- ENJOY!
BEFORE:
AFTER:
happy boosting!!!
tim85851
290
Oct 15, 2016 10:36 PM
tim85851
27
Jun 16, 2014 08:28 AM
tim85851
Aug 20, 2011 10:00 AM
