Another pump gas beast hits the streets of Ohio
#241
My best 60 so far was a 1.667 when I did the 11.0. The BFGs hook well at 16 PSI, just 42 has no track prep at all. The car is wanting to bouce around (not wheel hop) when coming off the line because the suspension isnt stiff enough. I have a set of Apexi N1s on order and Swift springs already at Buschur, I also have some aero stuff and other stuff sitting around and the V2 Manifold is supposed to be here this week!
Can you post up the run? With 1.6x 60fts. I am going 10.60's on straight pump gas.
The 1-2 shift is critical. If you are slow on that or you bog it in 2nd, the run is done. Are you letting it spin through 1st and letting the speed catch up to the RPM's then shifting into 2nd or once it starts spinning in 1st, you immediately go to 2nd and it bogs out??
#245
My 60s arent all that good! THat was by far the best run. Most of my 60s are around a 1.85-1.95. Myt 60s are what is killing me, after that is pretty good. My MPH got better every run last night. `My final run was the 137 pass. I am slowly getting there. I believe that if we would have been ar nborwalk last night that I would have easily gone 10s.
I just have to keep getting to the track and practicing. I know that it will come very soon.
#246
I think what Slo is trying to tell you is the 1.6 60' was good enough for a 10sec pass. Now it is possible that your shifting style is the cause for you to still be in the 11s...now what you can do is compare you slip with Slorice or Vwjeff when they trap 135+ and you probably narrow it down.
I'm really impressed with your trap speeds as it really shows your car is making good power on pump gas. Hope to see you run your first 10sec pass on pump soon...
Congrats again!
#247
I would seriously reconsider running your car at Marion. There are major potholes on the shutoff and I would not want to be going 130mph+ hitting one.
Congrats on the great car!
#248
^^BigBadQuattro hit the nail on the head.
Here is my run
I also went 11.08 @ 134.35 on a 1.89 60ft. Looks like the old saying of one tenth in the 60 ft. is worth two tenths in the 1/4 mile is true.
What does your 137MPH run look like?
Here is my run
Code:
60ft 1.6709 330ft 4.5997 1/8 ET 6.9660 1/8 MPH 101.51 1000ft 8.9480 1/4 ET 10.6470 1/4 MPH 135.07
#249
Here is my run
Here is my run
Code:
#251
I will post up the times tomorrow. All my slips are out in the car and I dont feel like going out and getting them.
I would have gone 10s on the 11.0 run if I would have no lift shifted. The last run I spun pretty bad coming off the line when I ran the 11.04 at 137, I think that my 60 was like a 1.8 or something.
#253
11.000 Run
RT: .845
60': 1.667
330': 4.70
594' ET: 6.727
1/8: 97.37
1/8: 7.188
1000': 9.254
1/4: 11.000
1/4: 132.69
11.04 run
RT .510
60 1.870
330 4.869
594 6.849
1/8 7.294
1/8 101.12
1000 9.329
1/4 11.045
1/4 137.62
RT: .845
60': 1.667
330': 4.70
594' ET: 6.727
1/8: 97.37
1/8: 7.188
1000': 9.254
1/4: 11.000
1/4: 132.69
11.04 run
RT .510
60 1.870
330 4.869
594 6.849
1/8 7.294
1/8 101.12
1000 9.329
1/4 11.045
1/4 137.62
#254
Im averaging picking up almost 36 MPH in the 2nd half! Its out of control!
Im going back to 42 again tomorrow! I was supposed to go to our schools event until I found out LaRue is worse than last year with the pot holes. So Im just going to 42 and going to keep digging for those 10s!
#255
Brian, you did an excelent job the other night. Keep driving the car the way you are doing, dont let everyone tell you how to drive. Seems eveyone is an expert on driving, but the only thing that will help you is practice. You just keep shifting the way you are untill YOU get comfortable, there is no need to go out and try power shifting and missing gears on every other pass, work on being consistent first.
Trent-
Trent-
