Buschur V Full Blower in-tank dual Pump
Im in the process of getting a twin intank pump.
Can anyone give me thier views between:
Buschur racing dual pump:
Full Blown - dual pump:
one uses the stock sending unit and the other is an Al. unit.
Full Blown FTW
I run one.
You need to send in a core for Buschurs. Fullblown you dont, You might as well pay for the anadiozed version inscase you wanna run some crazy fuels later on.
I run one.
Thats why
https://www.evolutionm.net/forums/sh...d.php?t=240268
I just installed the BR double pumper and it easy, it's like doing a drop in fuel pump, I just didn't know where to connect the hobb switch, but thanks to Dr. SS I know where now
![Big Grin](https://www.evolutionm.net/forums/images/smilies/biggrin.gif)
it's like an on and off switch that make the 2nd pump work at 7psi, all you have to do is connect it to a boost/vacuum soruce and your set, once the switch see 7psi it completes the circuit and energize the 2nd pump.
Speedevil,
can I set it up that the 2nd pump is constatly working?
because if this Hobb switch fails there will be a big bang once i hit boost. due to not enough fuel.
sparky
i havent got the got the double pumper yet i have put it on hold. I already have a 2.3 BR stroker. Im planning to get the BR GT35HTA with 1,200cc injectors and the dual pumper. i already have all the other supporting mods.
