Subframe Bolt Stripped - Any Ideas
Silver Sponsor
Been there.
Use a nut splitter and get the sucker off (parts store cheap). This will let you get the nut off without damage to the stud.
Drill a hole near where the stud goes into the sheet metal. What you want to do is get near the part of the stud encompassed within the sheet metal, then throw a tack weld up into the hole to hold it still. A few tacks may be needed, but this saves chopping the car apart. You may need to grind the tacks to allow for re installation of the sub frame.
Be careful listening to the other advice in this thread, minus the ASE cert guy. Advice that horrible can get you into trouble. You really will need a welder to properly do this though, maybe you can borrow one from a friend if you don't have a mig.
__________________
-Matt
http://www.SpoolinUp.com
Affordable COP Kits - Back in Stock!
"Performance without the Price Tag"
-Matt
Been there.
I'll let you know how it goes when I attempt it this weekend.
Silver Sponsor
It really does work great, used this method no less than 7-10 times on various cars. Just drill the hole in the right spot and tack away!
__________________
-Matt
-Matt
Do I really need to drill a hole, couldn't I just weld the bolt to the frame on the outside and then grind it down?
ooooo ok i see now lol....
Ok the only thing I can think of you will have to do is:
You will need a shop with the right tools, or if you have them even better.
What will have to be done is, they will need to cut that bolt off
remove the frame
cut open that housing/case inclosing that bolt head
remove ruined bolt/nut combo
Reweld a new bolt from the dealer(or lowes if you can find a similar setup) to the inside of that housing/case inclosing that bolt
Reweld shut that housing/case inlcosing the bolt
reinstall the frame when done doing what ever is being done
Good luck
remove the frame
Good luck
Been there.
Horrible advice? It basically the same as yours minus cutting the bolt off, which doesn't harm the car. And by the time you get the nut off, you may have to buy a new bolt, possible stripping. Your advice is still cutting into the car to just weld it. Same diff as mine lol. Besides its under the car and unless you are planning to flip the car over to show it, what diff does it make if you cut one of the walls out of the inclosure or make a hole, to do the same thing......tack weld the bolt still lol........ My advice isn't that far off from your's lol.....But whatever, good luck.........and you're welcome.
SJ
Silver Sponsor
Sure you could do that (weld outside), but keep in mind that the amount of grinding will increase quite a bit. It is normally a tight fit onto the stud and you want to maintain a flush surface around the stud. You only need to drill maybe two holes, each under 1/4". Just enough to get a good tack. Oh and don't forget to do the other stud too, you said it is wiggling.
__________________
-Matt
-Matt
update - I just removed the nut using a nut splitter, it turned out to be a pain in the *** because the nut had a washer built into it and I had to grind that off in order for the nut splitter to work properly.
I saw a tiny little whole that is already in the frame as a result of the building process, might be able to weld through that.
I will get you some pictures so that you can suggest what to do next.
Thanks a lot for the info, it has been very helpful so far!!
Silver Sponsor
Good job with the splitter! Are all the threads on the stud ok?
If you can reach the top of the stud through that hole, then all the work is done for you!
__________________
-Matt
-Matt
Yea the threads are all fine. At first I was having trouble getting the splitter to work properly, it was just slipping off. But after grinding down the top of the nut it worked just fine.
This happened to me on a customers car last week. I know exactly what your going through and can answer for experience not speculation.
On the car I was working someone had replace a stock clutch in the past. It seems they forced a rusted or damaged nut back on with an impact gun.
My first attempt was to drill a hole threw the sub frame and in to the shaft of the bolt so I could slide a punch in and hold the bolt in place well removing the nut. This may work for you but all it did for me was bend the tip of a hardened punch. If you do this make sure you drill 3/8ish hole. Has to be big enough for a strong punch but not so big that it drill half the bolt in half. Aslo make sure you drill very straight.
My second attempt was to jack the frame up and weld the bolt to the subframe. Even though I jacked the frame up the car still squeaks over bumps.
The car is coming back next week and I am just going with the most labor intense but correct route. You have to cut a hole in the side of the car. Cut 3 sides of a square and bend the metal out of the way. Then remove the bolt and weld a new one in place. Next you need to put the new nut on and be sure that it tightens up before closing the hole you cut. Once all is good fold the metal back in place, weld and paint.
BTW...does anyone know of a part number for that bolt?
Since I was able to get the nut off without damaging the bolt I am going to try and weld the bolt inplace without cutting into the frame. I am going to try and just weld the bolt to the frame from the outside.
If you do cut the frame of the car open and you find how the bolt is held inplace PLEASE PLEASE post some pictures of how things look inside that frame rail.
Thanks
Thanks
