need help, broken pressure plate bolt
My dumb a## jacked up a bolt for the pressure plate. I went to the parts store and the only bolt they had that would fit was a grade 8, 13mm bolt, everything else is the same as the stock one. The stock one looks to be a grade 7, 12mm. It fits but is it ok to use this bolt? I just don't want to have any issues down the road.
Using a different bolt will not be a problem. The stock bolts are not all that great. I would highly recommend either replacing all of them or using two of the different style bolts and place them directly opposite eachother so that any difference in weight is counteracted by the other bolt so balance will not be affected.
Nismo2k6
30
May 15, 2015 06:00 AM
D Grade
Mar 31, 2011 07:23 AM
brokenRS
Feb 9, 2010 07:20 AM
