Load before & after mods
This past weekend I put on my Forge WGA and tubular o2 housing and did a few pulls to adjust my timing and AFR to get them where they ought to be. Anyway before the installs with the stock WGA the boost would sort of "hit" and then slowly taper off. With the new WGA it builds hard and doesn't taper much at all. Anyway here are my 2byte load graphs from before and after.. Does this look normal for the aftermarket HD actuators?
Before:
After:
Here is my DLL dyno graph also.
Before:
After:
Ok, but not rpm control, that is why you see that "hump" in the boost curve with the actuator. You would see the same thing usually with the FP actuator as well.
This can be tuned out with a rpm based boost controller, or oem ecu controlled boost.
It's not a bad thing of course, but you do lose the "hit" without it.
Jon91TSi
For Sale - Part Outs
44
Oct 9, 2008 08:02 AM
