replacement oil temp gauge
It has to be tapped to get it to read sometimes. I want to put an aftermarket one in its place. Does anyone know if I can use the wiring already going to the gauge for an aftermarket gauge? I dont need anything fancy, maybe just an autometer. I also plan on getting rid of the stock boost gauge and replacing it with an a/f meter. I think I should also replace the voltage meter at the same time, jsut to give the gauge pod a uniform look. Anyone have experiance with this ?
Its been done several times.
You can buy pre molded pods that fit in the stock location. Obviously you can't use the boost wiring for the a/f, but the voltage and oil temp should be able to be wired with the stock wiring.
