Whistle/whine under boost
Hey guys,
I am kind of a noob when it comes to Evo's, so I need your help. I just bought a '06 Evo IX MR from the BMW dealer a couple days ago and I have been getting a kind of whistle/whine from the engine bay while under boost.
Sounds like this:
http://www.youtube.com/watch?v=F_FXe...eature=related
The car appears to be stock except for a badge on the back that says Dyno-Comp tuned. I am thinking that it is running lean because it was tuned with some upgrades and then put back to stock for trade in...
What do you all think? Thanks in advance!
Sounds like this:
Hey guys,
Sounds like this:
Sounds like this:
Sounds like you have a leaking intercooler pipe. It would be a good thing to look at all couplers and clamps, to make sure all are tight and non leaking. If it doesnt have the stock intake on it, then you will hear the turbo spooling. Another way to check isif you have a boost gauge, watch it and make sure the boost is not falling real bad. But i would def. see about getting a tune before something bad happens.
Well boost varies with different gears right. It takes a while to build boost while I am unsure of what stock levels are, it should hit peak and fall slowly.
I second the noise being a boost leak. Did you check all couplers? Look for holes in your pipes, and tighten the couplers then check to see if the problem persists.
You should be seeing low boost or vacum when at low accelerating, but when at full accelerating you should see no more than 23 or 24 psi. the boost will not come onto somewhere around 4k or little less, but if the car has a tune and someone has taken off parts i would def. check on getting a tune! But does the car have a intake or is it on the stock air box??
1 Post
Something else to consider is the early 65mm throttle bodies had a problem with whistling. The easiest way to tell if yours has been bored over is to pop the UICP pipe off at the throttle body and see if the throttle valve itself is made of bronze/ brass looking material. or you could take it off and measure. PM me and I'll see if I can take a picture of my stock one next to the 65mm ones I have been making.
Josh
Josh
its probably missing these plastics i just cant remember there names if u dont have them the snorkel is making a seal with the hood when or under accelaration, and never mind the k&n intake on the pic... check it if you have a stock intake, if you have an aftermarket intake then its something else
blackandredgts
Jan 1, 2014 07:26 AM
MadBoostedEvo
May 10, 2013 02:41 PM
jasnm21
Apr 28, 2009 03:37 PM
