EVO Red pump gas/race gas dyno numbers.
Old Jul 15, 2008, 09:02 PM
  #106
9sec9's Avatar
Thanks for that good info Razorlab. The main objection I have with someone telling me that my information is incorrect is 1: It's very common for 4th gear to show higher numbers than 3rd gear, regardless of the reason. If it's due to not synching the dyno, so be it. It still happens. Obviously, MilSpec has seen the same thing. 2: As 9sec240 said it was due to 'poor boost control' would assume that an ecu based, or electronic based boost controller will outperform a manual boost controller. I'm certain that many manual controllers are beating electronic based controllers every day. I agree that boost may be held to tighter windows on elect controllers, but the assumption that the manual is 'poor' means that anything other than electronic is 'poor' is an overstatement. Proper WG adjustment and manual controller adjustment work more than adequate on thousands of cars. 3: All of the 'peripheral' conversation as to synching, proper controller, etc simply skirts the original post he made which stated that 4th gear would not show 'big' differences to 3rd gear dyno pulls. It does everyday. That's real world. Theory may prove different, but I've observed the difference myself. Regardless of the reason.
Old Jul 15, 2008, 09:03 PM
  #107
RazorLab's Avatar
Received 1,056 Likes on 764 Posts
btw, I just want to make sure my post doesn't get mistaken for more than what it was.
I just posted that to show what I see on our Mustang dyno and share my experience with different gears on our Mustang dyno.
I want to make it clear I am not taking any sides in whatever other argument is going on here.
Make power not war.
Old Jul 15, 2008, 09:06 PM
  #108
RazorLab's Avatar
Yea again I want to make sure my post about boost control isn't taken the wrong way, maybe I should have said something other than "good boost control" in my post so it didn't sound like a gauntlet being thrown.
There are reasons not pretaining to this thread for the boost control we use 90% of the time. I won't clutter the thread with it.
  #109
SpoolnupTuning's Avatar
Congrats on Trents car David!! Wow i said mid 10's and it went 10.3 at 134, all i have to say is wow!!
Old Jul 15, 2008, 09:07 PM
  #110
Ivan@AMS's Avatar
Not sure, but EVERY book I have and every post I've read by many tuners such as Ford's own race teams have stated that ALL dyno pulls are to be done in the gear that is closest to 1:1. I have a tendency to believe that, since I've observed differences in 3rd and 4th gear pulls and these professional teams have reasons for stating that. I would tend to listen to their advice. Razorlab, I hear what you're saying, my only comment on that would be then, Why would the statement be made that most pulls are done in 3rd gear then, if they were both of equal value? I think that AMS has successfully hijacked another thread that had nothing to do with them or their car. It has to do with Trents car. I'll always keep an open mind to being corrected. I can handle that, since I'm not all knowing. What I don't keep an open mind on is how someone continues to create havoc in a Buschur oriented thread that just happens to be getting attention. Maybe it's a habit that should be broken. I wonder what Dynojet and Mustang recommend for doing dyno pulls?
You want to dyno tune at the highest load your vehicle will be seeing when under that load. For most, this would be 4th gear. You really shouldnt be racing in 5th gear.
My disagreement with your statement is has nothing to do with the gear you dyno in but the reason that you stated to be in that gear. HP numbers do not go up and down significantly in different gears. They do however change a lot in turbo cars when the boost changes due to increased load on the car.
If you have a properly working and set up dyno, HP numbers in 3rd gear are going to be almost identical in 4th gear. If they are not, then something else changed.
Its that simple.
Old Jul 15, 2008, 09:15 PM
  #111
RSGuy's Avatar
Let's get back on subject, the red.
Dave, would there be anyway you could overlay some stock/green/35R dyno graphs with one of the Red dyno graphs just to get a better picture of how good the red's powerband is? You did that with the green when that turbo came out comparing it to a 35R. Thanks.
Old Jul 16, 2008, 09:43 AM
  #112
spt
spt's Avatar
Couldn't of said it better myself. I am reluctant to reopen this thread, but I am hoping that we can all just calm down a bit and discuss the topic at hand. If topics continue to go off topic the thread will be closed and will not be reopened again. Also points will be issued for repeat offenders.
Old Jul 16, 2008, 09:59 AM
  #113
David Buschur's Avatar
Thank you very very much for opening the thread again. I greatly appreciate it.
For the guys who support me, please refrain from any dyno discussion in this thread. If the guy who wanted to debate would like to continue the discussion please open another thread and I will come right over to talk about it in detail.
So the subject is the Red is a bad *** MF'er. Let's get back to that! haha
Old Jul 16, 2008, 10:02 AM
  #114
EvoM Moderator
scheides's Avatar
Can't wait to see guys running this thing on stock block/stock ecu with a little alky injection in the mix! Should yield comparable numbers!
Old Jul 16, 2008, 10:36 AM
  #115
Falcon350z's Avatar
What kind of capabilities will the red have on a stock block with the stock ECU? Has BR done any kind of testing on an Evo with the usual bolt-on mods?
I've already built the head, but still have the stock turbo and don't have any plans of building the bottom. If the red is still a better choice than the green on a stock block, that would be awesome.
Old Jul 16, 2008, 11:00 AM
  #116
jmartinez1170's Avatar
So lets recap all bolt on turbos out for Evo 7-9
16g 9.8housing,16g 10.5housing (single or dual flapper) 16g TME, 20g 9 (6blade or five), 20g 8 (6blade or 5blade), white rabbit, green & red.
Im i missing anything.
All we need is a black turbo to come out and will be set LOL. But for real so many options they all seem the same. As time goes by tuning gets better and better and power could be found in many ways. It seems they make theses turbos but testing of said products being that there tested on different cars different tunes making the numbers not valid in my eyes. Seems to be a over hype to sell a product. If all products are better then one another get all turbos lock yourself in a engine dyno room and test every turbo all at the same parameters boost, tune, room temps, engine temps and so on. I know no one will do but it would be a better presentation of said product and clear all judgement of said product.
Thats my .02 cents i dont really care for stock turbos or stock appearing turbos. And i dont want to start any debates on it either cuz it will be pointless.
Old Jul 16, 2008, 12:08 PM
  #117
If you believe that all stock turbos are the same and the only reason the cars have gotten faster with the new turbos is because of tuning, then yes, a debate or discussion about it is absolutely 100% pointless.
Old Jul 16, 2008, 02:32 PM
  #118
bboypuertoroc's Avatar
+1
I, for one, am EXTREMELY impressed by the Red. I can't wait to re-up and get my bonus... I'll be picking one of these up as soon as the money hits my account.
Old Jul 16, 2008, 06:03 PM
  #119
2.3 Evo 8's Avatar
I for one, love brake boosting with a larger turbo. lol
Sweet results. Looks like one heck of a street turbo.
Old Jul 16, 2008, 08:36 PM
  #120
articfury's Avatar
nvm...
Quick Reply: EVO Red pump gas/race gas dyno numbers.
