GSC S2 idle
Old Jul 15, 2008, 02:30 PM
  #31
whytrySTi?'s Avatar
iirc the s2's are meant for bigger turbos. However, many people are running them on the stock turbo. I just ordered them and plan on running them on the stock turbo for a while.
Old Jul 15, 2008, 05:34 PM
  #32
Vapor's Avatar
i read the ams thread a long time ago, they didn't test the 272's only the S2's iirc.
Anyway, seems as though retarding the intake cam 4 degrees and the exhaust cam 1 degree seems to be the consensus choice for best idle and all around power from what i've read. Thoughts?
Old Jul 15, 2008, 08:49 PM
  #33
ethompson's Avatar
Any cam idling that lean is gonna lope pretty hard. Even the stock IX cams will lope pretty good.
Old Jul 15, 2008, 09:01 PM
  #34
slicedbreadno2's Avatar
Will check it out when I get home.
Old Jul 15, 2008, 11:29 PM
  #35
JohnBradley's Avatar
16-17 AFR with big cams is not acceptable for a smooth idle. Fuel in the high 13's low 14's smooths out the idle on big cams but is bad for emissions testing if required. The other tricks are timing and actual ISCV changes as well some hardware tuning.
Old Aug 3, 2008, 10:24 PM
  #36
Vapor's Avatar
thought i'd come back and tell you the resolution to the idle.
turns out, my mechanic forgot to plug in the hose to the intake for the pcv vent when he installed the cams and turbo. Totally explains why John had issues getting my idle afr correct. Sometimes its the simplest stuff that gets ya. Car runs much better now, idles very very well - like stock with a hiccup periodically. Post another vid tomorrow demonstrating the difference.
browningderek
AEM EMS
73
Mar 2, 2019 08:35 PM
TouringBubble
May 2, 2017 11:28 PM
Evo47
Dec 10, 2015 09:46 AM
Appauldd
Sep 21, 2015 08:39 AM
kaj
Jul 9, 2015 01:47 PM
Quick Reply: GSC S2 idle
