Mobil 1 Extended?
I use to use the "regular" mobil 1 synthetic and after changing it every 3000-3500 miles, the oil seem used up and dark. I shifted using "extended performance" mobil 1 synthetic and even at every 5000 oil changes, it looks better than the regular synthetic. After reading the product label, it says it has more supersyn and additives that is why it can last 15000 on a NA car.
The turbo is just another loop for the oil path. It probably helps the engine "consume" oil, but not a huge deal on changing habits. You should just check your level more than the average N/A 4 banger
dude, don't listen to him. if you're going to change your oil every 3k miles anyway, and the extended life version costs more, just save yourself some $$ and stick with regular M1.
if it were me, I'd run 5k intervals on regular M1... but you seem to be a bit more paranoid.
I use the M1-EP also..
great stuff.
And i also noticed the oil appears cleaner when i change it compared to the reg. M1..
Sure it costs a little more, but it works for me..
great stuff.
hmmm even if the cost is $5 more for a container at Wallmart....its still well worth it to use EP M1...very interesting...I guess for my next oil change I will try the EP...at the same time I doubt I will keep the car as long as the engine can last...lol...I don't know anyone that does...so maybe it is a waste of money...
i've been using the gold top for 30,000 miles and 6,000 intervals. No probs yet as I'm at 45,000 miles. What I do do is change the oil filter every 3K and fill it back up to the max amount on the dip stick.
The EP has a better additive package in the oil. Using it in an Evo is not about getting 10,000 miles between oil changes, it's just better protection when you are using it for higher performance demands on your motor.
This is the reason to invest in some serious M1 EP.
https://www.evolutionm.net/forums/sh...d.php?t=345944
