Mobil 1 Extended?
#34
Location: South Beach, FL / Miami, FL / Pt. St. Lucie, FL / NYC
OK I will add on this. I use whatever is available regular mobil 1 syn or extended syn. If I use extended I will actually keep it in the car longer then 3k. I change the oil on 5k but that is because I really don't push my car(gas is too expensive in the NYC area). Most of my driving is highway actually I have a little over 4k right now on the oil in the pan and it's still has that nice color to it. So for me it's whatever Walmart is stocking at that time but until I push crazy HP I'll stick with Mobil 1!
#35
I've been absent from my own thread.....just wanted to thank the moderator for your input ....for $4-$5 difference I'll definitely being moving the m1 EP....then completely thrashing...j.k.
#39
I use the regular M1 with 4500 mile changes in my Evo- I drive pretty gently. Sent a sample from the last change to blackstone and they said there was plenty of life left and 5500 mi would be no problem. I'll go to 5k since that's what Mitsu recommends for changes.
Like a few have said, unless you're road racing, 3k mile oil changes with synthetic is wasting money and time. I know it makes you feel better but it won't make any difference in engine life- something else is going to die first before you wear out the bearings from not changing the oil enough. For some proof, I have 285,000 miles on a 1G AWD Talon, never rebuilt, 3500-4000 mile changes with conventional oil. Oh, I'm the original owner. Same issue with the obsession most have here with the "best" oil filter- I've used Fram and then changed to Purolator on the Talon and the car is still going- purolator is just fine.
#40
Vibrant
Jul 19, 2008 06:46 PM
