AC works sometimes
The clutch is the problem.
If you take the clutch off, you will find a 20mm washer. Take the washer out & replace it with a 10mm washer. Put the clutch back on & wala. This will buy you sometime before you will need to replace the clutch & the coil.
It will take you about 15 mins to do. Its pretty easy.
Good luck!
Good luck!
Unless you have a leak you should not have to re-charge the system.
Sorry, I do not have pictures. Im sure if you were to go to a good shop they would be able to help you out. Tell them you need to change the shim
