Insecure wrist pin clips
Hi guys i am looking for some suggestions on what would cause wrist pin clips to come out of the pistons allowing the pin to move in the piston,
The car is a evo 6 that has had the standard pistons machined to accept floating pins to allow the fitment of forged rods the affected cylinders are numbers 2 & 3
The clips have come out of the same side on both pistons
The clips were found in the sump when it was removed any comments would be very helpful
Did the piston use 2 locks per side or only one? I can see you installed aftermarket rods. Many pistons use 2 spiro locks per side, but some people only install one. Big mistake! The pin will eventually push the lock out.
If not, you may want to check the end float when the wrist pin is installed. In others words, how much can the wrist pin slide back and forth in the pin bore before hitting the lock?
There was only one clip installed on each side of the pin,
It has been suggested to me that ignition det has shocked the clips and pins out
Does anyone think this would be possible or has anyone heard of det causing wrist pin clips and pins to come out ?
No, detonation did not "shock" the clips out.
Measure the thickness of the lock (not diameter) and compare that to the width of the lock groove in the piston. If there is too much room for the lock to move back and forth with the pin, it will eventually get pushed out. The lock must be supported in the groove.
If this isn't the case, it was mostly likely installed incorrectly or didn't have enough clearance from the end of the pins. The edge of your wrist pins is straight, right? If there is a taper on the end, that will also push the lock out.
Thanks for the relplies they are very helpful
WTB[Pacific NW]: Looking for performance rods / pistons
03lances
Aug 1, 2017 05:19 PM
4g63girl
Oct 11, 2016 02:46 PM
FS[SouthEast]: JE Pistons 85mm bore
hutch959
23
Sep 12, 2016 05:17 PM
FS[SouthEast]: Wisco HD Pistons with upgrade wrist pins
Howulikemyevo
Jul 22, 2016 12:38 PM
