Dc Sports Dp Rubbing?
I'm a bit confused as to why my DC Sports Downpipe is rubbing (against the tcase I believe). I've searched around and everyone seems to say that this dp is a perfect fit but mine was REALLY close to rubbing and now after a week of driving, I just checked and now it is rubbing + i can tell when the car is on that its rubbing. It does clear the cross member though...
Any ideas as to what I may have messed up during installation? I know getting the pipe thru the hangers was a complete bych and I could only get one side in. The right side is being supported by the hanger but its not going through the hole its supposed to be going through. I'm going to try and fix that and see if it gives the pipe enough clearance but do you guys think this is the problem? Theres really no possible way I put it on crooked because even if I did, once i tightened the dp bolts, it would have corrected itself no? I'm not too comfortable knowing that the pipe is rubbing and I don't want it to turn into a serious problem.
98autogstspyder
33
Dec 7, 2009 12:52 PM
GinNBoost
32
Jul 4, 2008 08:11 PM
