Teaser pictures of the new RPS billet twin plate carbon clutch
Couple quick ???. From the pics it looks like carbon coated metal discs. wouldn’t that make them prone to warping from heat and defeating the point of using carbon? Also would it be available in a smaller 7.25 version? Is that a aluminum flywheel? What is the weight of the unit?
i think a smaller 7.25" version would defeat the purpose as i doubt it could be packaged in such a small size and still hold 700wtq unless it was a triple disc...
The old set up was using factory style pressure plate(it's bellit aluminum now) and the base of discs and floaters were made out of steel(it's also aluminum) .We had some problems with the car moving forward on the lunch and some high rpm shifting issues,not to mention that new style is using hydraulic t/o bearing.When i pick up the clutch from RPS, ROB the owner of the RPS brought up a good subject,he was saying that one of the biggest problems with the hi performace cluthes is warpage of the discs and floaters,cooling them down after each dyno run or drag race run or back on the pits after road racing by just depressing the clutch pedal to separate the discs and floaters from flywheel and pressure plate helps a lot.
Ihad the last RPS twin carbon clutch...
held up to some fantastic high RPM launches..one after the other.
however, the center clip on the pressure plate eventually gave way and that was the end.
price comes with the territory, make enough power and you will NEED to spend that much on a clutch.
The exedy twin carbon (MSPR $3058) holds 500wtq the RPS billet twin carbon holds 700wtq (msrp $3295). Which one do you really think is overpriced? Unless your referring to exedy's non carbon units but then you can't really compare.
Is there a clutch out there for much less money that will be good enough for most peoples power goals? Hell yes, but for the people that wanna get nasty with the power the twin billet is pretty sick I'm looking forward to driving impressions
I was actually talking about the Exedy twin Carbon/Carbon and the price i have have to say is lower than $3058. People have tested the exedy carbon hundreds of times and know it works on cars over 500wtq and RPS just CLAIMS it holds 700wtq. Only time will tell and i am very interested in the results.
i just noticed the flywheel and pressure plate as well as floaters have carbon on them too, not sure but last time i installed an exedy those parts where not carbon, can anybody confirm this for sure? It's been a while since i did a clutch job, and IIRC i wanna say carbonetics does not have carbon on pressure plate or flywheel either... TTT for confirmation...
GBAILEY472
For Sale - Part Outs
18
Mar 14, 2013 08:52 AM
04lancerEsGuy
17
Apr 21, 2011 09:42 AM
04lancerEsGuy
Nov 25, 2009 08:09 PM
