My Evo is shooting out smoke
Old Aug 10, 2008 | 09:45 PM
MumeiEvolution's Avatar
My evo is shooting out white and black smoke, but mainly white.
I was wondering if someone can tell me what might be the problem.
I know i didnt give much information about my car so I know it's kind of hard to say, but maybe someone might still know a reason why this is happening.
Old Aug 10, 2008 | 11:36 PM
evo_q8's Avatar
Black - is prolly coz ur car is running rich..
White - Dunno but its usually something you get fixed ASAP!
Old Aug 10, 2008 | 11:46 PM
bluebanana23's Avatar
black is fuel
blue is oil
white is coolant
Old Aug 10, 2008 | 11:53 PM
sikrsix's Avatar
brown is
Old Aug 10, 2008 | 11:55 PM
streetvision's Avatar
if its white its probably coolant
Old Aug 10, 2008 | 11:58 PM
vboy425's Avatar
Originally Posted by bluebanana23
black is fuel
blue is oil
white is coolant
what he said. i will put into more detail.
blue is oil- mean bad piston ring.
white- head gasket is not sealing.
check your coolant reservoir and radiator for oil spot. Take the dip stock out and look for milky color. do the same with the oil cap, look down inside the valve cover. doo this when the engine is cold/been sitting
Also take off the hose that goes form the left side of the valve cover to the intake pipe "Blow pipe" turn on the car and see what color it's blowing out.
Old Aug 11, 2008 | 01:18 AM
hanahawaiian's Avatar
did u have APR head stud or u on high boost drive...
white mean coolant into engine.. that mean head gasket bad.. or stock head bolt stretch out
Old Aug 11, 2008 | 01:47 AM
exacc's Avatar
You can easily check if it is coolant getting into engine, if you open your oil filler cap and check for mayo-like substance on it.
Old Aug 11, 2008 | 02:17 AM
RPRalliart04's Avatar
Originally Posted by sikrsix
brown is
I love yoohoo!!!! Haha!
Old Aug 11, 2008 | 07:46 AM
tonyk's Avatar
Just curious, what kinds of mods do you have on your car? Sorry, but it really does sound like a head gasket. That white smoke is all too familiar to me (back in the old Datsun 210 days). Good luck.
tk
Old Aug 11, 2008 | 09:07 AM
andreww238's Avatar
i had a blown turbo in my talon.. the smoke seemed pretty white to me so i thought i was burning coolant.. but nope.. pop ur LICP off and if its loaded with oil.. turbos gone
Old Aug 11, 2008 | 01:25 PM
sonicnofadz's Avatar
Heres what you should do for a complete diagnosis.
1. Empty contents of your coolant system (from radiator) into clear plastic pitcher for examination. If you find oil its your headgasket.
2. Empty contents of your engine oil (from oil pan) into clear pastic pitcher for examination. If you find coolant its your headgasket.
3. Check your intake tract for excessive amounts of oil. If there is a lot of oil you might have blown the turbo, or piston rings.
4. Do a compression check (or leak down test is even better) to determine if valves, headgasket, or piston rings are blown.
Old Aug 11, 2008 | 03:38 PM
EvoJoeIX's Avatar
brown is
HAHAHAHAHA
yoohoo FTMFW!!!!!
Old Aug 11, 2008 | 03:44 PM
SLO-EVO's Avatar
what he said
Old Aug 12, 2008 | 09:42 AM
hempele28's Avatar
i had the oil return line get pinched off in my aftermarket turbo set up. it pissed out white smoke to the point i clouded my whole block. oil dumped into the exhaust since it had no where else to go. check some oil lines to.
Quick Reply: My Evo is shooting out smoke
