With my supporting mods in my signature is the exedy twin disc a good idea with an MR
So the question is with my mods which should be in the signature. Is the exedy twin disc a good idea on the MR 9. Thanks in advance.
Jon at TRE doesn't recommend anything over a 2900lbs. pressure plate on the Evo 6 speed. I am not sure how the twin-disc impacts that thought, but my guess is Jon might say no.
With the mods you have an ACT 2900lbs. clutch should do fine. I have more hp than that with a Green, and I have 30,000+ miles on mine 2900lbs. unit.
I have an EXEDY TWIN HD on my MR..I would reccoment this for a car at STOCK POWER LEVELS all the way up to 600whp or so..The clutch is not noisey at all, barely noticable at all even with a quiet exhaust, less chatter then most of the single disc clutches I have driven INCLUDING STOCK OEM, awesome pedal feel and engagement, not heavy at all, awesome shifting and engagement under racing conditions, plus it is rebuildable..I will not buy a different clutch for the evo for as long as I have the car unless I am forced to or something terribly wrong happens..The clutch would be awesome for your mods dude, I don't know why someone would reccomend a limit on the pressure plate rating on the 6 speed and not the 5 I have a hard time understanding the reasoning behind that though.
I brought up this clutch specifically because sean ivey recomended it to me, and he has done awesome work for me so far, and he's a good guy but, I did wanna see if there are any other opinions so I will pm his guy, and then post the reply
The gears only weakness is they're lack of mass, they heat up when driving in the same gear under heavy load for extended periods of time. I can honestly say that I truley believe any type of clutch will have absolutely zero effect on this problem and the only time you need to worry about the smaller gears in the MR transmission is when you get them hot enough to harden.
Just my opinion though.
AMS Performance recommends the Exedy Twin also. I am looking for that same clutch for my IX MR. I don't think AMS would try to mislead me either. With all the work they did, the cars going great. Yea i'm sure they would perfer the 5-speed, but I think the 6-speed is a bit stronger than everyone thinks. I beat the crap outta mine and at 25,000 miles its still perfectly fine.
Gears 1-3 are of a larger width on the MR then they are on the 5 speed, sadly the gears after that suffer from heat problems due to their smaller size..It's not really a stregnth issue, it's an engineering mistake that cannot be corrected due to the tight tolerences around the effected gears so no upgrades are available.
