Camshafts for Evo red... idle, revlimit, power
Old Aug 17, 2008, 09:19 PM
  #61
GrocMax's Avatar
Just because the flow bench says flow goes flat above xxx lift doesn't mean power will not increase with more lift. If it goes super-turbulent and backs up THEN you might have a problem.
Think in 2 stroke terms such as Time Area or Time Angle.
NHRA SS records alone should prove this, broken several times every year on puny valves and ports that have lots of time into them. They go WELL above the stall lift.
Old Aug 17, 2008, 09:31 PM
  #62
Turbo Kyle's Avatar
^ good point
Old Aug 17, 2008, 11:21 PM
  #63
Erik@MIL.SPEC's Avatar
Yeah, so that's the kind of stuff Aby understands...me, not as much
I mean, I can understand it but I was a liberal arts major, not no engineer with fancy phrases like stall lift
Old Aug 18, 2008, 01:50 AM
  #64
Ted B's Avatar
Originally Posted by sparky
Ted: Is the cylinderhead of your JAM VIII engine unported? And if so, is this why you have stuck with the relatively low lift, HKS cams on your own engine ?
At this moment, my engine is receiving a new head that is CNC ported and subsequently hand finished, with a custom cam profile. The old setup was just temporary until this one was ready.
At this point, that would be conjecture. Regardless, a competently ported head comfortably outflows a factory head at all lift ranges, especially high lift ranges.
Old Aug 18, 2008, 11:41 AM
  #65
Ludikraut's Avatar
Originally Posted by Ted B
HKS 280s are fine with a factory head and valvetrain, and that's about it. They are outclassed by offerings with better ramp rates, such as the cams we are discussing here. But then again none of the cams we are discussing here should be used with the factory valvetrain, period.
You just had to say that, didn't you?
I'm still running HKS 280s, but I've been thinking about swapping them for something a little bit bigger, esp. now that I have a ported head ... I'm just not sure how much more I can squeeze out of my 50 trim.
l8r)
Old Aug 18, 2008, 01:45 PM
  #66
Ted B's Avatar
LOL
The only reason why I kept HKS cams in my head is because there was no sense in changing them until I upgraded the head.
HKS cams are designed to improve power with a factory head and valvetrain, without compromising reliability. They achieve exactly that, and cannot be faulted. However, there is no sense in using any HKS cam set with a ported head and upgraded valvetrain. The turbo will spool quicker and the engine will make more power with a more aggressive cam set.
Old Aug 18, 2008, 10:55 PM
  #67
Ludikraut's Avatar
I've been thinking about going with a set of Kelford 272s. I'm not sure that going much more aggressive than that would pay off on a car that sees mostly street and road course use. Then again, I do have a block that can be revved well past where the 50 trim will reasonably hold up, so something like a set of GSC S3's or Kelford 280s would be very tempting to try. Might be too much cam for the smaller turbo, but should work that much better with something like an HTA 35R. Choices, choices...
l8r)
Old Aug 19, 2008, 05:49 AM
  #68
Ted B's Avatar
Size the cams for the turbo, and resist the temptation to use more duration than you really need. It will only hurt you on the low side of things, which tends to be counterproductive for anything driven on the street.
Old Aug 19, 2008, 12:17 PM
  #69
STikiller.com's Avatar
Originally Posted by markymark1082
Some people have started to think that Kelford and GSC cams are the same with different names. Just a thought.
i started to think that as well.... then i made the payment on a $1.4 million grinder...
Originally Posted by Erik@MIL.SPEC
You might wanna check out the BR 272's. I heard they're similar.
They actually are not that similar. we doctored both the Jun 272 and the BR 272..
Greg
Old Aug 19, 2008, 02:52 PM
  #70
john.schuber's Avatar
I think the GSC S3's are only used for the garret 42r and 1000 +whp. Did you guys test the JUN 272's compared to the BR 272 and any other related cam.
Old Aug 19, 2008, 03:59 PM
  #71
we didn't test either of them.. we just cam doctored them to check the spec for the customers that set them to us..
the S3 can be used on a smaller turbo than the 42r.. just needs to be on a top end power car. the S3 set i would run on a 67mm turbo car that is a drag car or a larger turbo. pretty much needs to be on a ported head and will really work well in the 5500-9000 rpm range. then again..
Old Aug 19, 2008, 05:13 PM
  #72
Ludikraut's Avatar
Originally Posted by STikiller.com
...the S3 can be used on a smaller turbo than the 42r.. just needs to be on a top end power car. the S3 set i would run on a 67mm turbo car that is a drag car or a larger turbo. pretty much needs to be on a ported head and will really work well in the 5500-9000 rpm range. then again..
Hehe, that's the range my 50 trim operates in most of the time...
... so the real question is - if my 50 trim is already maxed out past 7500 RPM, would the S3 gain me any top end versus the HKS 280s I have right now? ... or does the turbo ultimately limit the potential gains from the bigger cam?
l8r)
Old Aug 19, 2008, 07:47 PM
  #73
CBRD's Avatar
l8r)
you just need a custom 50 trim upgrade lol... jk
cb
jmb_silvester
13
Nov 25, 2019 01:26 PM
Jeffs2006EVOIX
Aug 29, 2010 06:51 PM
webby06
Jan 1, 2010 09:28 PM
RyeLou
35
Apr 29, 2009 09:37 AM
blueprint
23
Jan 18, 2009 07:14 AM
Quick Reply: Camshafts for Evo red... idle, revlimit, power
